24in Vinyl Cutter
Status Operational
Zone Laser
Owner LMN
Tool Type Vinyl Cutter
Member Category Coder/Crafter
User Manual laserpoint_manual.pdf
Manufacturer US Cutter
Model LaserPoint 24in
SOPs Link
Checkout Required
barcodeDon't have barcode reader? Click here.
Description
Makes really big and or small stickers
Contacts for training
  • Rose Canino-Koning
  • Brian Adams
  • Nick Kwiatkowski
  • Joe Zimmerman
Specifications
24 in wide cutter
Workflow
  1. import vector drawing
  2. ensure the image is a vector.
    1. If not see manuals section “Converting a Raster Image to Vector Image”
  3. select cut
  4. select cut
  5. select finish
Software & Drivers
In short…
Install “SignBlazer Elements for USCutter” The interface to the LaserPoint24 is Serial. The LP24 has both a DB9 or USB. Where the USB will install as a FDTI and should auto install. If needed drivers are available at http://support.uscutter.com/index.php?/Knowledgebase/List/Index/39
SignBlazer is a free design and cutting utility for Windows O/S only. It suits the needs of many customers but lacks much of the power and functionality of true design programs such as,CorelDraw or Inkscape (inkscape.org). The official release of SignBlazer only works in “Trial Mode” but it is fully functional. It also does not require an activation code of any kind; nor do you need to register or update it because it is no longer being developed.
http://support.uscutter.com/index.php?/Knowledgebase/Article/View/190/27/01-signblazer-elements
Consumables
  • Rolls of vinyl
  • Transfer Tape
Tutorials
Please read the following sections of the manual, they are quite short and straight forward.
  • “Selecting a Location for Your Cutter”
  • “Starting SignBlazer”
Maintenance
Please roll and store leftover vinyl, and dispose of vinyl pickings. The cutting blade muat be replaced periodically. Xarrax says the $5 ebay blades broke less often and cut longer than the expensive ones in this machine.
Resources
