dotnetrobotknifefight [2013/09/10 03:15] – zimmer62dotnetrobotknifefight [2017/04/05 00:38] (current) – external edit 127.0.0.1
Line 12: Line 12:
 [[https://groups.google.com/forum/#!topic/lansing-makers-network/H2Ycka4clho|Google Groups Topic]] [[https://groups.google.com/forum/#!topic/lansing-makers-network/H2Ycka4clho|Google Groups Topic]]
-I have mounted IR compound eye's to each robot using the exact same build procedure so the robots will have identical hardware... for now.{{:user:zimmer62:img_6640.jpg?direct&200|}}{{:user:zimmer62:img_6641.jpg?direct&200}}{{:user:zimmer62:img_6643.jpg?direct&200|}}{{:user:zimmer62:img_6642.jpg?direct&200|}}+I have mounted IR compound eye's to each robot using the exact same build procedure so the robots will have identical hardware... for now.
 +{{:user:zimmer62:img_6640.jpg?direct&200|}}{{:user:zimmer62:img_6641.jpg?direct&200}}{{:user:zimmer62:img_6643.jpg?direct&200|}}{{:user:zimmer62:img_6642.jpg?direct&200|}}
Line 20: Line 22:
 I like how i3 has an overhead camera tracking the locations to be beamed to the robots for further usage, not sure if I'll get that extreme or not though. I like how i3 has an overhead camera tracking the locations to be beamed to the robots for further usage, not sure if I'll get that extreme or not though.
 http://www.youtube.com/watch?v=exUIDctnmfQ http://www.youtube.com/watch?v=exUIDctnmfQ
 +Useful information on using the [[http://3amcode.blogspot.com/2012/05/net-gadgeteer-object-tracking-using-ir.html|IR Compound Eye with Gadgeteer]]
 +Todo:
 +  - Determine how multiple robots will be able to use IR sensors at the same time
 +     * One possible method would be to have them take turns and signal when it's safe for the other to turn on it's IR.  I would think some experimentation would be needed to have this work
 +  - Define rules
 +  - Build battle arena
