| Next revision | Previous revision | ||
| dotnetrobotknifefight [2013/09/09 23:17] – created zimmer62 | dotnetrobotknifefight [2017/04/05 00:38] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| - | [[https:// | + | {{:user: |
| I bought two FEZ cerbot from GHI | I bought two FEZ cerbot from GHI | ||
| Line 9: | Line 9: | ||
| The robots have a pair of reflectivity sensors on the front. | The robots have a pair of reflectivity sensors on the front. | ||
| + | [[https:// | ||
| I have mounted IR compound eye's to each robot using the exact same build procedure so the robots will have identical hardware... for now. | I have mounted IR compound eye's to each robot using the exact same build procedure so the robots will have identical hardware... for now. | ||
| I envision having a balloon kill switch, and a IR start command to start the fight. | I envision having a balloon kill switch, and a IR start command to start the fight. | ||
| Line 17: | Line 22: | ||
| I like how i3 has an overhead camera tracking the locations to be beamed to the robots for further usage, not sure if I'll get that extreme or not though. | I like how i3 has an overhead camera tracking the locations to be beamed to the robots for further usage, not sure if I'll get that extreme or not though. | ||
| http:// | http:// | ||
| + | Useful information on using the [[http:// | ||
| + | Todo: | ||
| + | - Determine how multiple robots will be able to use IR sensors at the same time | ||
| + | * One possible method would be to have them take turns and signal when it's safe for the other to turn on it's IR. I would think some experimentation would be needed to have this work | ||
| + | - Define rules | ||
| + | - Build battle arena | ||
