user:zimmer62:autodvdloaderrobot:start [2013/09/21 16:46] – zimmer62user:zimmer62:autodvdloaderrobot:start [2017/04/05 00:38] (current) – external edit 127.0.0.1
Line 18: Line 18:
   * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]   * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]
   * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]   * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]
 +    * Pin 1 = Red = Emitter Anode
 +    * Pin 2 = Orange = Emitter Cathode
 +    * Pin 3 = Yellow = Sensor Emitter
 +    * Pin 4 = Green = Sensor Collector
   * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]   * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]]
   * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E)   * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E)
Line 23: Line 27:
   * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E)   * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E)
   * JP13 Greyish White Wires go to the Disc Release Solenoid.   * JP13 Greyish White Wires go to the Disc Release Solenoid.
-  * Stepper Motor FL42STH47-1206AC +  * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] (1.8 degrees 1.2A)
-     * 1.8 degrees 1.2A+     * Rated Voltage = 4V
 +     * Current / Phase = 1.2A
 +     * Resistance / Phase 3.3Ω
 +     * Inductance / Phase 2.8mH
 +     * Holding Torque = 3.17Kg-cm
 +     * Rotor Inertia = 68g-cm^2
 +     * Detent Torque = 200g-cm
   * Power Supply 12V @ 2.5A   * Power Supply 12V @ 2.5A
 +{{:user:zimmer62:autodvdloaderrobot:motor-windings.jpg?direct&200|}}
 This should be enough information to get going. This should be enough information to get going.
Line 46: Line 58:
 +I had a heck of a time getting the .net gadgeteer board and the L6470 stepper controller to talk to any stepper motor.
 +I was finally able to get this turning a stepper motor over the weekend.  It seems it's very sensitive to it's register settings.
 +I had to use some software and a stepper motor datasheet to get some values to feed into their software.
 +According to this:
 +https://www.ghielectronics.com/community/forum/topic?id=8081&page=2
 +Those values only get you close and you need to use an o-scope to tune it further.
 +TODO:
 +  * Hookup and test stepper motor to L6470 module
 +  * Verify resistors and voltage coming into micro-controller.
 +  * Write some rough code to exercise the machine using the optical sensors to prevent damage
 +    * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full.
 +  * Write code to interface machine to PC to take simple commands and report back
 +  * Write code on PC side to control machine and rip discs
 +9/30/2013
 +Andrew and I learned how to interface with the Disc Presence sensor.  It was very easy
 +  * Blue Wire to Ground
 +  * Red Wire to 5V
 +  * Black Wire to Pin 3 (interrupt pin)
 +<code csharp>
 +        public bool IsDiscPresent { get { return !diskPresenceSensor.Read(); } }
 +        private Gadgeteer.Interfaces.InterruptInput diskPresenceSensor;
 +        private void SetupDiscPresenceSensor()
 +            char_Display.PrintString("DiscSensorSetup");
 +            diskPresenceSensor = breadBoard_X1.SetupInterruptInput(GT.Socket.Pin.Three, GT.Interfaces.GlitchFilterMode.On, GT.Interfaces.ResistorMode.PullUp, GT.Interfaces.InterruptMode.RisingAndFallingEdge);
 +            diskPresenceSensor.Interrupt += diskPresenceSensor_Interrupt;
 +            diskPresenceSensor.Read();
 +        void diskPresenceSensor_Interrupt(GT.Interfaces.InterruptInput sender, bool value)
 +            char_Display.Clear();
 +            char_Display.PrintString(IsDiscPresent.ToString());
 +</code>
 +I wrote down the documentation on how we hooked up the other sensor.  We still need to verify the input voltages.  I'm pretty sure this board expects 3 volt inputs, not 5 to prevent damage.
