Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
user:zimmer62:autodvdloaderrobot:start [2013/10/01 02:32] – zimmer62 | user:zimmer62:autodvdloaderrobot:start [2017/04/05 00:38] (current) – external edit 127.0.0.1 | ||
Line 72: | Line 72: | ||
TODO: | TODO: | ||
- | * Interface both types of optical sensors to gadgeteer board | + | * Verify resistors and voltage coming into micro-controller. |
* Write some rough code to exercise the machine using the optical sensors to prevent damage | * Write some rough code to exercise the machine using the optical sensors to prevent damage | ||
* A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | ||
Line 105: | Line 105: | ||
+ | I wrote down the documentation on how we hooked up the other sensor. | ||
