user:tim:start [2014/11/18 14:45] – timuser:tim:start [2017/04/05 00:38] (current) – external edit 127.0.0.1
Line 68: Line 68:
     * http://www.appropedia.org/Open-source_mobile_water_quality_testing_platform     * http://www.appropedia.org/Open-source_mobile_water_quality_testing_platform
     * [[https://github.com/timschmidt/bailingwire|bailingwire]]     * [[https://github.com/timschmidt/bailingwire|bailingwire]]
 +      * http://jhnet.co.uk/articles/cpp_magic
       * pointers and arrays: http://pw1.netcom.com/~tjensen/ptr/ch2x.htm       * pointers and arrays: http://pw1.netcom.com/~tjensen/ptr/ch2x.htm
       * finish serial support bringup in bailingwire       * finish serial support bringup in bailingwire
Line 100: Line 101:
     * http://www.greenhousegrower.com/uncategorized/manage-ph-and-soluble-salts-in-hydroponics/ - I think salts are best avoided through careful nutrient use, and drainage into a constructed ecosystem     * http://www.greenhousegrower.com/uncategorized/manage-ph-and-soluble-salts-in-hydroponics/ - I think salts are best avoided through careful nutrient use, and drainage into a constructed ecosystem
   * HeirloomTech (ThirdCoastCollective?)   * HeirloomTech (ThirdCoastCollective?)
 +    * create gridbeam https://www.udemy.com/ course - income
     * check that domain is pointed     * check that domain is pointed
     * set up wordpress     * set up wordpress
Line 127: Line 129:
     * http://www.bkent.net/Doc/simple5.htm     * http://www.bkent.net/Doc/simple5.htm
     * http://crud-admin-generator.com/ / http://www.sandman.io/     * http://crud-admin-generator.com/ / http://www.sandman.io/
-    * prepare for LP C visiting week of 10/20
     * Seminar in session signs      * Seminar in session signs
     * thisability video - leigh     * thisability video - leigh
Line 136: Line 137:
     * https://play.google.com/store/apps/details?id=com.vidyo.vidyoremote&hl=en     * https://play.google.com/store/apps/details?id=com.vidyo.vidyoremote&hl=en
     * centralize domains - beacon-center.org, and friends. - https://tech.msu.edu/network/dns.php / http://network.msu.edu/public/ipadmin.html     * centralize domains - beacon-center.org, and friends. - https://tech.msu.edu/network/dns.php / http://network.msu.edu/public/ipadmin.html
-    * finish remote admin setup+    * set up apple remote desktop
     * finish test wordpress plugin for displaying projects in admin interface     * finish test wordpress plugin for displaying projects in admin interface
     * Video Conferencing     * Video Conferencing
Line 165: Line 166:
     * send a wordpress theme to smart design     * send a wordpress theme to smart design
     * get videos to jay / do them yourself on the second imac     * get videos to jay / do them yourself on the second imac
-    * back up nescent data / webpage
     * finish pcard statement     * finish pcard statement
     * evosphere vpn     * evosphere vpn
     * http://www.sshguard.net/     * http://www.sshguard.net/
     * nescent training session resources: http://www.nescent.org/wikis     * nescent training session resources: http://www.nescent.org/wikis
-    * recomission mbp w/ ssd
     * https://github.com/NESCent/TraitDB - CSV cleanup, validation, merging     * https://github.com/NESCent/TraitDB - CSV cleanup, validation, merging
     * investigate graphite logging / graphing framework     * investigate graphite logging / graphing framework
Line 179: Line 178:
   * Home   * Home
 +    * http://forum.solar-electric.com/showthread.php?16120-Compare-Nickel-Iron-Edison-Batteries-and-Chinese-Ni-Fe-Cells/page4
 +    * http://edison.rutgers.edu/battpats.htm
 +    * http://www.survivalistboards.com/showthread.php?t=276932
 +    * www.changhongbatteries.com/down/index/626873e633e0f71bea6f796a23088d9f.pdf
     * honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]]     * honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]]
     * improve dryer efficiency: http://www.alkeng.com/AL/dryer     * improve dryer efficiency: http://www.alkeng.com/AL/dryer
