user:tim:start [2014/11/06 16:11] – timuser:tim:start [2017/04/05 00:38] (current) – external edit 127.0.0.1
-cTimothy Schmidt+Timothy Schmidt
   * BOARD MEMBER 5/8/2012 - 5/8/2016   * BOARD MEMBER 5/8/2012 - 5/8/2016
Line 8: Line 8:
 ====== projects ====== ====== projects ======
   * LMN   * LMN
 +    * https://github.com/openSUSE/libsolv - https://www.youtube.com/watch?v=GhwXzWb79sY
     * teardrop "wheatlander"     * teardrop "wheatlander"
       * draw / price in emachineshop       * draw / price in emachineshop
Line 67: Line 68:
     * http://www.appropedia.org/Open-source_mobile_water_quality_testing_platform     * http://www.appropedia.org/Open-source_mobile_water_quality_testing_platform
     * [[https://github.com/timschmidt/bailingwire|bailingwire]]     * [[https://github.com/timschmidt/bailingwire|bailingwire]]
 +      * http://jhnet.co.uk/articles/cpp_magic
       * pointers and arrays: http://pw1.netcom.com/~tjensen/ptr/ch2x.htm       * pointers and arrays: http://pw1.netcom.com/~tjensen/ptr/ch2x.htm
       * finish serial support bringup in bailingwire       * finish serial support bringup in bailingwire
Line 99: Line 101:
     * http://www.greenhousegrower.com/uncategorized/manage-ph-and-soluble-salts-in-hydroponics/ - I think salts are best avoided through careful nutrient use, and drainage into a constructed ecosystem     * http://www.greenhousegrower.com/uncategorized/manage-ph-and-soluble-salts-in-hydroponics/ - I think salts are best avoided through careful nutrient use, and drainage into a constructed ecosystem
   * HeirloomTech (ThirdCoastCollective?)   * HeirloomTech (ThirdCoastCollective?)
 +    * create gridbeam https://www.udemy.com/ course - income
     * check that domain is pointed     * check that domain is pointed
     * set up wordpress     * set up wordpress
     * set up login for rachel to wordpress     * set up login for rachel to wordpress
-    * build / document gridbeam drill press w/ rachel photographing +    * build / document [[gridbeam drill press]] w/ rachel photographing
-      * welded nut plate for edge of carriage +
-      * welded clamp bolts / handles +
-      * welded clamp angle brackets / nuts +
-      * stepper motor mount +
-      * hdpe cutting sheet slides +
-      * leadscrew rests on carriage deck, under clamps+
     * build solar fridge, document and publish, sell kits     * build solar fridge, document and publish, sell kits
       * Find affordable dc compressor       * Find affordable dc compressor
Line 116: Line 113:
     * set up wordpress plugins - woocommerce, anti-spam, etc.     * set up wordpress plugins - woocommerce, anti-spam, etc.
   *BEACON   *BEACON
 +    * establish expected annual budget for maintenance, upkeep, recurring costs based on past expenses
     * http://www.ebs.msu.edu/Technical/OSBrowsersAdobeRAM.htm     * http://www.ebs.msu.edu/Technical/OSBrowsersAdobeRAM.htm
     * http://blog.mourafiq.com/post/58725341511/end-to-end-web-app-with-django-rest-framework     * http://blog.mourafiq.com/post/58725341511/end-to-end-web-app-with-django-rest-framework
Line 131: Line 129:
     * http://www.bkent.net/Doc/simple5.htm     * http://www.bkent.net/Doc/simple5.htm
     * http://crud-admin-generator.com/ / http://www.sandman.io/     * http://crud-admin-generator.com/ / http://www.sandman.io/
-    * prepare for LP C visiting week of 10/20
     * Seminar in session signs      * Seminar in session signs
     * thisability video - leigh     * thisability video - leigh
Line 140: Line 137:
     * https://play.google.com/store/apps/details?id=com.vidyo.vidyoremote&hl=en     * https://play.google.com/store/apps/details?id=com.vidyo.vidyoremote&hl=en
     * centralize domains - beacon-center.org, and friends. - https://tech.msu.edu/network/dns.php / http://network.msu.edu/public/ipadmin.html     * centralize domains - beacon-center.org, and friends. - https://tech.msu.edu/network/dns.php / http://network.msu.edu/public/ipadmin.html
-    * finish remote admin setup+    * set up apple remote desktop
     * finish test wordpress plugin for displaying projects in admin interface     * finish test wordpress plugin for displaying projects in admin interface
     * Video Conferencing     * Video Conferencing
Line 169: Line 166:
     * send a wordpress theme to smart design     * send a wordpress theme to smart design
     * get videos to jay / do them yourself on the second imac     * get videos to jay / do them yourself on the second imac
-    * back up nescent data / webpage
     * finish pcard statement     * finish pcard statement
     * evosphere vpn     * evosphere vpn
     * http://www.sshguard.net/     * http://www.sshguard.net/
     * nescent training session resources: http://www.nescent.org/wikis     * nescent training session resources: http://www.nescent.org/wikis
-    * recomission mbp w/ ssd
     * https://github.com/NESCent/TraitDB - CSV cleanup, validation, merging     * https://github.com/NESCent/TraitDB - CSV cleanup, validation, merging
     * investigate graphite logging / graphing framework     * investigate graphite logging / graphing framework
Line 180: Line 175:
   * mUVe3D   * mUVe3D
     * SCARA Laser     * SCARA Laser
-    * spend more time reading about http://www.khronos.org/collada/
     * http://www.aixiz.com/store/product_info.php/cPath/28/products_id/103/osCsid/04316145f471c0a4aa5b41fee593ad78     * http://www.aixiz.com/store/product_info.php/cPath/28/products_id/103/osCsid/04316145f471c0a4aa5b41fee593ad78
-    * http://61extensions.com/shop/quickbooks-integration-woocommerce/+    *
   * Home   * Home
 +    * http://forum.solar-electric.com/showthread.php?16120-Compare-Nickel-Iron-Edison-Batteries-and-Chinese-Ni-Fe-Cells/page4
 +    * http://edison.rutgers.edu/battpats.htm
 +    * http://www.survivalistboards.com/showthread.php?t=276932
 +    * www.changhongbatteries.com/down/index/626873e633e0f71bea6f796a23088d9f.pdf
 +    * honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]]
     * improve dryer efficiency: http://www.alkeng.com/AL/dryer     * improve dryer efficiency: http://www.alkeng.com/AL/dryer
     * solar     * solar
Line 202: Line 201:
 ====== items to acquire ====== ====== items to acquire ======
 +  * http://www.sks-bottle.com/
   * http://www.menards.com/main/p-2261380-c-13136.htm   * http://www.menards.com/main/p-2261380-c-13136.htm
   * http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016 for nvidia jetson   * http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016 for nvidia jetson
Line 259: Line 259:
  * build asset maps for LMN - committee  * build asset maps for LMN - committee
  * identify asset goals, and a plan to fill them  * identify asset goals, and a plan to fill them
- * include community members on board committees+   * who do we need (what skills, resources?)
 +   * where do we find them
 +   * how do we communicate our mission
 +   * who's their number one priority?
 + * include community members on board committees - voting rights? adjust bylaws
  * build issue-focused teams for each committee  * build issue-focused teams for each committee
- * annual nonprofitnetwork board training, org reflection / reevaluation + * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation
- * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer + * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting
- * mission: skills and access+ * mission: education and access
 ====== references ====== ====== references ======
