user:tim:gridbeam_drill_press [2014/11/18 16:25] – timuser:tim:gridbeam_drill_press [2017/04/05 00:38] (current) – external edit 127.0.0.1
-===BOM===+based on: http://www.openbuilds.com/builds/mini-v-linear-actuator-build.48/
 +===Openbuilds BOM===
   * $10 2x http://openbuildspartstore.com/v-slot-actuator-end-mount/   * $10 2x http://openbuildspartstore.com/v-slot-actuator-end-mount/
   * $13 4x http://openbuildspartstore.com/mini-v-wheel-kit/   * $13 4x http://openbuildspartstore.com/mini-v-wheel-kit/
Line 6: Line 8:
   * $7 1x http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pulley-30/   * $7 1x http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pulley-30/
   * $5 1x http://openbuildspartstore.com/smooth-idler-pulley-kit/   * $5 1x http://openbuildspartstore.com/smooth-idler-pulley-kit/
-  * 3x http://openbuildspartstore.com/v-slot-20-x-40mm/+  * $39 3x http://openbuildspartstore.com/v-slot-20-x-40mm/
   * $9 1x http://openbuildspartstore.com/mini-v-plate/   * $9 1x http://openbuildspartstore.com/mini-v-plate/
   * $2 2x http://openbuildspartstore.com/belt-crimp-clamp/   * $2 2x http://openbuildspartstore.com/belt-crimp-clamp/
Line 13: Line 15:
   * $3 4x http://openbuildspartstore.com/double-tee-nut/   * $3 4x http://openbuildspartstore.com/double-tee-nut/
   * $2 6mm http://openbuildspartstore.com/socket-head-screws-m3-25-pack/   * $2 6mm http://openbuildspartstore.com/socket-head-screws-m3-25-pack/
 +===Gridbeam BOM===
 +  * aluminum 1.5" gridbeam
 +  * 1/8 inch x 2 inch perforated aluminum plate
 +  * 90 deg angle stepper motor mount
 +  * 90 deg angle bearing block
 +  * 1/8 inch aluminum plate carriage
 +  * 1/8 inch apeture rollers
 +  * nuts, bolts, spacers for rollers
