infrastructure_working_group [2015/08/05 19:42] – zimmer62infrastructure_working_group [2017/04/05 00:38] (current) – external edit 127.0.0.1
Line 27: Line 27:
 +=== Current Setup: ===
 +  * SSID: LansingMakersNetwork
 +  * Password: Written on the wall in many places around the space
 +If you see any of these access points with the light showing anything other than a solid Green, it would be helpful if you can report that here and the members list.
 +Please do not plug in any additional access points without asking the members list and consulting this working group.
 +=== Change Log: ===
 +9/14/2015 upgraded firmware on all three AP's from 3.2.5.2791 to 3.2.12.2920
 === Questions that need to be addressed: === === Questions that need to be addressed: ===
 (Educated guesses are okay here) (Educated guesses are okay here)
Line 54: Line 64:
   - How will we allow for VPN connections from outside the building into the member only network?   - How will we allow for VPN connections from outside the building into the member only network?
   - How will we allow for members to run servers using static or dynamic IPs?   - How will we allow for members to run servers using static or dynamic IPs?
 +=== Items to recommend: ===
 +  * Ubiquiti Networks UniFi AP Enterprise WiFi System UAP-3 (Pack of 3)
 +    * Pros:
 +      * Under $200 for 3 pack, but only supports 2.4ghz
 +      * These come with power injectors.
 +    * Cons:
 +      * only supports 2.4ghz
 +    * Info:
 +      * [[https://www.ubnt.com/unifi/unifi-ap/|Manufacturer Link]]
 +      * [[http://www.amazon.com/Ubiquiti-Networks-UniFi-Enterprise-System/dp/B005EORRBW/ref=sr_1_1?ie=UTF8&qid=1438804839&sr=8-1&keywords=UAP-3|Amazon $192.76]]
 +      * NOT 802.1af (48v) compatible -- from amazon review.  need more info if that matters or what it means?
 +    * Additional Equipment needed:
 +      * We will need a cheap switch, or switch with POE injeciton
 +      * Cat6 wire to install
 +      * Cat6 termination ends
 +  * Ubiquiti TS-8-PRO ToughSwitch 8 Port Advanced Power Ethernet Controllers
 +    * Pros:
 +      * 24V/48V Passive PoE
 +      * 8 Ports
 +    * Info:
 +      * [[http://www.amazon.com/Ubiquiti-TS-8-PRO-ToughSwitch-Advanced-Controllers/dp/B00CXU1NHY/ref=pd_sim_147_5?ie=UTF8&
 +refRID=1WEN598N7N6TPV4Y7C3W|Amazon $178.90]]
 +OR
 +  * Ubiquiti TS-5-POE TOUGHSwitch 5 Port Advanced Power Ethernet Controllers
 +    * Pros:
 +      * Price
 +    * Cons:
 +      * 24V Passive PoE Only
 +      * Only 5 Ports
 +    * Info:
 +      * [[http://www.amazon.com/Ubiquiti-TS-5-POE-TOUGHSwitch-Advanced-Controllers/dp/B00CXTK90W/ref=pd_sim_147_1?ie=UTF8&refRID=1WEN598N7N6TPV4Y7C3W|Amazon $82.59]]
Line 74: Line 124:
     * Suggested by a network admin of a small community college      * Suggested by a network admin of a small community college
     * Cost is around $700 for a 3 pack of routers     * Cost is around $700 for a 3 pack of routers
 +  * Shielded vs Unshielded Cat6
 TODO: add links and research TODO: add links and research
-  * Ubiquiti Networks UniFi AP Enterprise WiFi System UAP-3 (Pack of 3)
-    * Under $200 for 3 pack, but only supports 2.4ghz
   * POE switch for access points   * POE switch for access points
 +    * What is 802.1af
     * Ubiquiti TS-8-PRO ToughSwitch 8 Port Advanced Power Ethernet Controllers     * Ubiquiti TS-8-PRO ToughSwitch 8 Port Advanced Power Ethernet Controllers
     * Ubiquiti TS-5-POE TOUGHSwitch 5 Port Advanced Power Ethernet Controllers     * Ubiquiti TS-5-POE TOUGHSwitch 5 Port Advanced Power Ethernet Controllers
 +  * Additional RJ45 ports in the space
 +    * It was requested a port be added near the Coder Farm area.
