equipment [2014/01/10 02:54] – timequipment [2025/07/23 18:37] (current) – lex
-These are tools available to use at the space:+====== Equipment ======
-^ CNC tools ^ Owner ^ Description ^ Current Location ^ +The most up-to-date list of equipment can be found on the website. [[https://www.lansingmakersnetwork.org/equipment/|Equipment List]]
-| Vinyl Cutter | Xarrax Lee | USCutters 2ft cutting width | LMN - Craft area| +
-| Vinyl Cutter | [[user:voidptr:start|Rosangela Canino-Koning]] | 8 1/2" x 11" cutting size | LMN - Craft area| +
-| [[:equipment/buildlog_laser_cutter|Laser cutter]] | [[user:tim:start|Timothy Schmidt]] | 24inch square working area 40watt, [[http://buildlog.net/]] laser cutter | LMN - Mezzanine| +
-| PCB mill | [[user:tim:start|Timothy Schmidt]] | 8 inch x 6 inch x 2 inch CNC dremel mini-mill | LMN - Parts storage| +
-| 3D Printers | [[user:tim:start|Timothy Schmidt]] | Two mendel style [[http://www.reprap.org/|repraps]] | LMN - Mezzanine| +
-| [[http://muve3d.net | mUVe 1]] SLS 3D printer | [[user:tim:start|Timothy Schmidt]] | LMN - Mezzanine | +
-| Rostock 3D Printer | LMN | Rostock 3d printer | LMN - Mezzanine | +
-| Solidoodle2 | [[user:zimmer62:start|Joe Zimmerman]] | Solidoode2 3d Printer | LMN - Mezzanine| +
-| [[equipment:shapeoko|Shapeoko router]] | [[user:zimmer62:start|Joe Zimmerman]] | http://www.shapeoko.com/ | LMN - Basement| +
-| CNC Mill | [[user:carlraymond:start|Carl Raymond]] | Seig X2 mill converted to CNC with Mach 3 | LMN - Metalshop| +
-^Crafting^ ^ ^ ^ +
-| Embroidery Machine | [[user:zimmer62:start|Joe Zimmerman ]] | Built-in graphics and fonts, as well as custom computer-generated graphics via memory card / reader | LMN | +
-| Sewing Machine | LMN | Brother (non embroidery) - needs repair | LMN - Craft area | +
-| Sewing Machine | ?? | ?? | LMN - Craft area| +
-| Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | LMN - Craft area | +
-| Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | LMN - Craft area| +
-^Metal working ^ ^ ^ ^ +
-| Drill Press | [[user:tim:start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott | +
-| Lathe | [[user:tim:start|Timothy Schmidt]] | Harbor Freight [[ http://bedair.org/9x20camlock/9x20project.html|9x20]] metalworking lathe | LMN - Metalshop | +
-| Lathe | [[user:carlraymond:start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop| +
-| Angle grinder | [[user:tim:start|Timothy Schmidt]] | 5 inch angle grinder | ? | +
-| Welder | [[user:tim:start|Timothy Schmidt]] | 90A 110v flux core wire welder | [[user:tim:start|Timothy Schmidt]] | +
-| Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | LMN | +
-| Pipe bender | [[user:tim:start|Timothy Schmidt]] | 12 ton harbor freight [[http://www.harborfreight.com/12-ton-hydraulic-pipe-bender-32888.html|pipe bender]] | LMN | +
-| Horizontal Cut-Off Band Saw | [[user:tim:start|Timothy Schmidt]] | ?? | LMN | +
-| Pipe notcher | [[user:tim:start|Timothy Schmidt]] | harbor freight [[http://www.harborfreight.com/pipe-tubing-notcher-42324.html|pipe notcher]] | LMN | +
-| 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | LMN | +
-^ Wood working ^ ^ ^ ^ +
-| Table saw | [[user:carlraymond:start|Carl Raymond]] | Delta table saw | LMN - Woodshop | +
-| Table saw | LMN | Rockwell table saw | LMN - Woodshop | +
-| Router table | [[user:carlraymond:start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop | +
-| Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop | +
-| [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement storage| +
-| Band Saw | LMN | Large free standing band saw | LMN - Woodshop | +
-| Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | LMN - Parts storage| +
-| Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | LMN - Woodshop| +
-| Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | LMN | +
-| Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | LMN - Woodshop| +
-^ Electronics ^ ^ ^ ^ +
-|Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | +
-|Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | +
-| Hot-air rework station | [[user:carlraymond:start|Carl Raymond]] | SparkFun 303D | LMN | +
-|Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | +
-^Video^ ^ ^ ^ +
-|Inflatable Movie Screen | [[user:zimmer62:start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| LMN - Great room | +
-|3M Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | LMN - Alcove | +
-|Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | LMN - Great room | +
-|Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner.  Coaxial, RCA, and S-Video inputs| LMN - Parts storage| +
-^Communications^ ^ ^ ^ +
-|Sipura SPA 2002|[[user:tim:start|Timothy Schmidt]]|10/100 ethernet SIP Analog telephone adapter w/ two independent phone ports| LMN - Parts storage| +
-^Library^ ^ ^ ^ +
-^ Miscellaneous ^ ^ ^ ^ +
-| Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | LMN - Parts storage| +
-| Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | LMN | +
-| Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | LMN | +
-^Hand tools^ ^ ^ ^ +
-| 18 Volt Drill | LMN | Ryobi 18Volt drill | LMN - Woodshop | +
-| 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | LMN - Woodshop | +
-| Screw drivers | LMN | | LMN - Woodshop | +
-| Wrenches | LMN | | LMN - Woodshop / Metalshop | +
-======Wish List====== +
-^ Item ^ Comment ^ +
-| Air Compressor | bigger the better | +
-| Vacu-Former | [[user:wreality:start|Brian Adams]] will help/build/lead the project if there's no other takers | +
-| MIG / TIG welding equipment | | +
-| Mitre Saw | | +
-| Planer | [[user:zimmer62:start|Joe Zimmerman]] has one, it's currently on loan to a friend in Grand Rapids |  +
-| Jointer | | +
-| Bridgeport Mill | Manual or CNC | +
-| Drill press | Floor standing | +
-| Arbor press | Hand-operated rack-and-pinion press for installing bearings or broaching | +
-| [[http://www.tools-plus.com/general-woodworking-machinery-50-exbc14.html|General Woodworking Machinery 50-EXBC14 Overarm Blade Guard]] | Besides looking fancy, this thing clears away dust, and is trivial to move out of the way when necessary and back into place afterward - making it a blade guard people might actually use| +
-|screen printer| | +
-| Large cnc embroidery machine| | +
-|car hoist| | +
-|clay body mixer| | +
-|ceramic slab roller| | +
-|pottery wheels| | +
-|electric kilns|hot enough for glass work?| +
-|cnc knitting machine| | +
-|relief printing equipment|carving tools, presses| +
-|loom| | +
-|cnc foam cutter| Hot wire foam cutter http://www.instructables.com/id/Make-a-CNC-Hot-Wire-Foam-Cutter-from-parts-availab/| +
-|cnc fabric cutter|essentially a giant vinyl cutter w/ vacuum table for holding the fabric securely during cutting| +
-|shop press|10 ton or more shop press | +
-|cnc plasma cutter| such as: [[http://torchmate.com/products/]] |+
 +All Areas have an Area Manager, who facilitates and organizes the space and tools. If you have issues with any tools, please let them know by posting on the [[https://talk.lansingmakersnetwork.org/|talksite]].
 +Have an idea for an improvement that you'd like to see? Reach out!
 +The Area Manager list can be found on the website. [[https://www.lansingmakersnetwork.org/leadership/|Area Managers]]
