| zones:3d_printing_area [2014/11/06 09:40] – jfahner3 | zones:3d_printing_area [2016/01/28 13:29] (current) – Fixed some outdated info. wreality | ||
| Line 3: | Line 3: | ||
| ===About=== | ===About=== | ||
| - | The 3D Printing Area is located on the top floor of Lansing Makers Network. | + | 3D printers live here. |
| ===Stewards=== | ===Stewards=== | ||
| - | Zone Steward: | + | Zone Steward: :ORPHANED: |
| ===3D Printing Zone Tools / Equipment=== | ===3D Printing Zone Tools / Equipment=== | ||
| Line 39: | Line 39: | ||
| * Get the Makerfarm printing reliably | * Get the Makerfarm printing reliably | ||
| * Progress: Hot end installed and tested. | * Progress: Hot end installed and tested. | ||
| - | * Progress: Extra long probe arms printed in case they are needed - laying near printer | + | - Question: New hot end topped out at 206 degrees, is that a firmware issue? |
| - | * [[user:tim:start|Tim Schmidt]]: determine the offset between nozzle and bed leveling | + | * Progress: Jerry Fahner: Longer (blue) |
| - | * [[user:tim:start|Tim Schmidt]]: configure and install updated firmware | + | * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y. |
| - | * [[user:tim:start|Tim Schmidt]]: test printing | + | * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help. |
| - | * FIXME (unclaimed): | + | * Progress: |
| * Refurbish the solidoodle 2 3D printer | * Refurbish the solidoodle 2 3D printer | ||
| * Looking for someone to help with the completion of this project. | * Looking for someone to help with the completion of this project. | ||
| - | * Progress: Joe Zimmerman | + | * Progress: |
| * FIXME (unclaimed): | * FIXME (unclaimed): | ||
| * FIXME (claimed): run motor and hotend wiring | * FIXME (claimed): run motor and hotend wiring | ||
| - | - A crimper and ends have been ordered and received | + | - A crimper and ends to put new ends on the motors and existing wiring |
| - | - The fan will need a DC-DC power step down converter which is on hand, but needs to be set for 12volts | + | - The fan will need a DC-DC power step down converter which is on hand at the space, but needs to be set for 12volts |
| * Build a [[https:// | * Build a [[https:// | ||
