zones:3d_printing_area [2014/10/26 22:39] – timzones:3d_printing_area [2016/01/28 13:29] (current) – Fixed some outdated info. wreality
Line 3: Line 3:
 ===About=== ===About===
-The 3D Printing Area is located on the top floor of Lansing Makers Network.+3D printers live here.
 ===Stewards=== ===Stewards===
-Zone Steward: [[user:tim:start|Tim Schmidt]]+Zone Steward: :ORPHANED:
 ===3D Printing Zone Tools / Equipment=== ===3D Printing Zone Tools / Equipment===
Line 26: Line 26:
   * organize group-purchase filament orders   * organize group-purchase filament orders
   * establish a regular meeting schedule   * establish a regular meeting schedule
 +  * establish LMN-purchased stock, which can be paid for per-print via Cura / Repetier cost estimation
 +  * purchase / install fast-heating bed heaters on all printers: http://www.ebay.com/itm/like/191353869307?lpid=82
 +  * maintain two or more working 3D printers at all times.
 ===Ongoing Projects=== ===Ongoing Projects===
 +  * 3D print a buildlog.net laser cutter rotational axis: http://www.buildlog.net/blog/2011/04/open-source-rotational-adapter-part-1/
 +    * Progress: not started
 +    * FIXME (unclaimed): download the assembly STEP file, and export each printed part into an STL http://www.buildlog.net/wiki/doku.php?id=rotational
 +    * FIXME (unclaimed): print parts
 +    * FIXME (unclaimed): assemble and install in laser, connect motor to electronics
 +    * FIXME (unclaimed): modify laser cutter firmware for rotational axis
   * Get the Makerfarm printing reliably   * Get the Makerfarm printing reliably
     * Progress: Hot end installed and tested.  Extruding works!     * Progress: Hot end installed and tested.  Extruding works!
-    * [[user:tim:start|Tim Schmidt]]: determine the offset between nozzle and bed leveling probe, and update the printer's wiki page. +      - Question: New hot end topped out at 206 degrees, is that a firmware issue?
-    * [[user:tim:start|Tim Schmidt]]: configure and install updated firmware +    * Progress: Jerry Fahner: Longer (blue) probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK.
-    * [[user:tim:start|Tim Schmidt]]: test printing +    * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y.
-    * FIXME (unclaimed): soak magma hotend in acetone - it's already disassembled and in the glass container. +    * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help.
-  * Refurbish the solidoodle 3D printer +    * Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container.
-    * Progress: Joe Zimmerman has design for laser-cut base to contain power supply, electronics, and LCD. +  * Refurbish the solidoodle 2 3D printer
-    * FIXME (unclaimed): upload Joe's design to the wiki+    * Looking for someone to help with the completion of this project.
 +    * Progress: [[user:zimmer62:start|Joe Zimmerman]] has started another design for laser-cut base to contain power supply, MEGA / Ramps, Solid State Relay, Terminal Block etc.  A mount for the electronics, and LCD also needs to be created, possibly into the front of the base.
     * FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic?     * FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic?
     * FIXME (unclaimed): install power supply, electronics, LCD     * FIXME (unclaimed): install power supply, electronics, LCD
-    * FIXME (unclaimed): run motor and hotend wiring+    * FIXME (claimed): run motor and hotend wiring
 +       - A crimper and ends to put new ends on the motors and existing wiring are at the space.
 +       - The fan will need a DC-DC power step down converter which is on hand at the space, but needs to be set for 12volts
     * FIXME (unclaimed): laser cut improved magnetic side walls     * FIXME (unclaimed): laser cut improved magnetic side walls
   * Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer   * Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer
Line 48: Line 60:
   * Improve the frame of the Rostock by replacing it's MDF with aluminum extrusion.  Some 3D printed parts may need to be replaced.   * Improve the frame of the Rostock by replacing it's MDF with aluminum extrusion.  Some 3D printed parts may need to be replaced.
     * Progress: establish bill of materials     * Progress: establish bill of materials
 +    * FIXME (unclaimed): print http://www.thingiverse.com/thing:516447/
