zones:3d_printing_area [2014/05/13 17:56] – wrealityzones:3d_printing_area [2016/01/28 13:29] (current) – Fixed some outdated info. wreality
 {{ :zones:top_floor.png?direct |}} {{ :zones:top_floor.png?direct |}}
 +FIXME Have an idea or status update for this page?  Please add it! FIXME
 ===About=== ===About===
-The 3D Printing Area is located on the top floor of Lansing Makers Network.  +3D printers live here.
 ===Stewards=== ===Stewards===
-Zone Steward: [[user:tim:start|Tim Schmidt]]+Zone Steward: :ORPHANED:
 ===3D Printing Zone Tools / Equipment=== ===3D Printing Zone Tools / Equipment===
Line 12: Line 15:
 filter  : zone=3D Printing filter  : zone=3D Printing
 +===Goals===
 +  * promote the use of 3D printing technologies within the makerspace - software, hardware, and 3D printed products
 +  * showcase the makerspace's 3D printing
 +===Plan===
 +  * collect / adapt / develop a training curriculum
 +  * inventory and document printers on this page, linking to firmware, modified parts, etc.
 +  * create real-life FIXME tags, with a spot to write-in the issue, and a way to affix them to an item
 +  * organize group-purchase filament orders
 +  * establish a regular meeting schedule
 +  * establish LMN-purchased stock, which can be paid for per-print via Cura / Repetier cost estimation
 +  * purchase / install fast-heating bed heaters on all printers: http://www.ebay.com/itm/like/191353869307?lpid=82
 +  * maintain two or more working 3D printers at all times.
 +===Ongoing Projects===
 +  * 3D print a buildlog.net laser cutter rotational axis: http://www.buildlog.net/blog/2011/04/open-source-rotational-adapter-part-1/
 +    * Progress: not started
 +    * FIXME (unclaimed): download the assembly STEP file, and export each printed part into an STL http://www.buildlog.net/wiki/doku.php?id=rotational
 +    * FIXME (unclaimed): print parts
 +    * FIXME (unclaimed): assemble and install in laser, connect motor to electronics
 +    * FIXME (unclaimed): modify laser cutter firmware for rotational axis
 +  * Get the Makerfarm printing reliably
 +    * Progress: Hot end installed and tested.  Extruding works!
 +      - Question: New hot end topped out at 206 degrees, is that a firmware issue?
 +    * Progress: Jerry Fahner: Longer (blue) probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK.
 +    * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y.
 +    * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help.
 +    * Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container.
 +  * Refurbish the solidoodle 2 3D printer
 +    * Looking for someone to help with the completion of this project.
 +    * Progress: [[user:zimmer62:start|Joe Zimmerman]] has started another design for laser-cut base to contain power supply, MEGA / Ramps, Solid State Relay, Terminal Block etc.  A mount for the electronics, and LCD also needs to be created, possibly into the front of the base.
 +    * FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic?
 +    * FIXME (unclaimed): install power supply, electronics, LCD
 +    * FIXME (claimed): run motor and hotend wiring
 +       - A crimper and ends to put new ends on the motors and existing wiring are at the space.
 +       - The fan will need a DC-DC power step down converter which is on hand at the space, but needs to be set for 12volts
 +    * FIXME (unclaimed): laser cut improved magnetic side walls
 +  * Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer
 +    * Progress: Collecting parts
 +    * FIXME (unclaimed): print two motor brackets
 +    * FIXME (unclaimed): pull 3 NEMA-23 motors from the parts area
 +    * FIXME (unclaimed): acquire makerslide
 +  * Improve the frame of the Rostock by replacing it's MDF with aluminum extrusion.  Some 3D printed parts may need to be replaced.
 +    * Progress: establish bill of materials
 +    * FIXME (unclaimed): print http://www.thingiverse.com/thing:516447/
