user:zimmer62:projects:cherrypi-iii-build [2015/05/22 23:46] – zimmer62user:zimmer62:projects:cherrypi-iii-build [2015/05/23 00:02] (current) – zimmer62
Line 3: Line 3:
    * 5/22/2015     * 5/22/2015
      * Printed [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]]      * Printed [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]]
 +       * [[http://youtu.be/ziopiy626Cs]] Here is a timelapse of these parts
      * Printed 4x [[http://www.thingiverse.com/thing:487476|Mini V Wheel Carriage for OpenBuild Extrusions]]      * Printed 4x [[http://www.thingiverse.com/thing:487476|Mini V Wheel Carriage for OpenBuild Extrusions]]
        * Chose to print 4, so I'd have a spare, and because it lined up nicely on the plate (probably a wasted part)        * Chose to print 4, so I'd have a spare, and because it lined up nicely on the plate (probably a wasted part)
Line 13: Line 14:
    * 5/21/2015 Some parts started to arrive, such as stepper motors and some screws and nuts.     * 5/21/2015 Some parts started to arrive, such as stepper motors and some screws and nuts.
    * 5/20/2015 3D printed parts for base.    * 5/20/2015 3D printed parts for base.
 +{{:user:zimmer62:projects:parts_as_of_may_20.jpg?direct&200|}}
    * 5/19/2015 Tried acetone vapor bath just fro the heck of it.    * 5/19/2015 Tried acetone vapor bath just fro the heck of it.
 {{:user:zimmer62:projects:spool_disk_2.jpg?direct&200|}} {{:user:zimmer62:projects:spool_disk_2.jpg?direct&200|}}
Line 20: Line 23:
    * 5/18/2015 Start of the Cherry Pi III project    * 5/18/2015 Start of the Cherry Pi III project
-     * Ordered Many Many parts online+     * Ordered Many Many parts online most were sourced from eBay, Amazon, or openbuilds.com
Line 29: Line 32:
     * http://www.magnet4less.com/ need to figure out what to order     * http://www.magnet4less.com/ need to figure out what to order
 +Extruder:
 Tim recomended the [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]] Tim recomended the [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]]
-Many parts were sourced from eBay, Amazon, or openbuilds.com+
 I like this [[http://www.thingiverse.com/thing:651472|Lightweight end effector plate for Delta]] But it would need various  modifications depending on what we attach to it. I like this [[http://www.thingiverse.com/thing:651472|Lightweight end effector plate for Delta]] But it would need various  modifications depending on what we attach to it.
Line 37: Line 41:
 Interesting ideas Interesting ideas
   * http://www.spiderbot.eu/en/technology/tss-three-sphere-system.html   * http://www.spiderbot.eu/en/technology/tss-three-sphere-system.html
 the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/specified length) x delta rod length = new delta rod length the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/specified length) x delta rod length = new delta rod length
Line 43: Line 46:
 tips... fan motor not spinning tips... fan motor not spinning
 If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi. If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi.
 +Slicing
 Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height. Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height.
-It appears a different size carriage will be needed for the v-slot extrusions +I have been using slic3r with a .3mm layer height and a 20% infill.  I've been printing all parts in ABS
-http://www.thingiverse.com/thing:487476+----
 +Notes:
 +It appears a different size carriage will be needed for the v-slot extrusions:
 +[[http://www.thingiverse.com/thing:487476|Mini V Wheel Carriage for OpenBuild Extrusions]]
 http://forums.reprap.org/read.php?178,361141,page=17 This page here has someones build log where we can see how it's assembled http://forums.reprap.org/read.php?178,361141,page=17 This page here has someones build log where we can see how it's assembled
