| user:zimmer62:autodvdloaderrobot:start [2013/09/30 09:56] – zimmer62 | user:zimmer62:autodvdloaderrobot:start [2013/10/01 16:42] (current) – zimmer62 | ||
| Line 18: | Line 18: | ||
| * Bad Disk Full (Orange, Yellow, Green, Blue) [[https:// | * Bad Disk Full (Orange, Yellow, Green, Blue) [[https:// | ||
| * Bin Full (Red, Orange, Yellow, Green) [[https:// | * Bin Full (Red, Orange, Yellow, Green) [[https:// | ||
| + | * Pin 1 = Red = Emitter Anode | ||
| + | * Pin 2 = Orange = Emitter Cathode | ||
| + | * Pin 3 = Yellow = Sensor Emitter | ||
| + | * Pin 4 = Green = Sensor Collector | ||
| * Drive Door (Blue, Black, Purple, Yellow) [[https:// | * Drive Door (Blue, Black, Purple, Yellow) [[https:// | ||
| * Home Sensor (Red, Orange, Yellow) [[http:// | * Home Sensor (Red, Orange, Yellow) [[http:// | ||
| Line 32: | Line 36: | ||
| * Detent Torque = 200g-cm | * Detent Torque = 200g-cm | ||
| * Power Supply 12V @ 2.5A | * Power Supply 12V @ 2.5A | ||
| This should be enough information to get going. | This should be enough information to get going. | ||
| Line 65: | Line 71: | ||
| TODO: | TODO: | ||
| - | * Find datasheet for stepper motor in machine | ||
| * Hookup and test stepper motor to L6470 module | * Hookup and test stepper motor to L6470 module | ||
| - | * Interface both types of optical sensors to gadgeteer board | + | * Verify resistors and voltage coming into micro-controller. |
| * Write some rough code to exercise the machine using the optical sensors to prevent damage | * Write some rough code to exercise the machine using the optical sensors to prevent damage | ||
| * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | ||
| Line 74: | Line 79: | ||
| + | 9/30/2013 | ||
| + | Andrew and I learned how to interface with the Disc Presence sensor. | ||
| + | * Blue Wire to Ground | ||
| + | * Red Wire to 5V | ||
| + | * Black Wire to Pin 3 (interrupt pin) | ||
| + | <code csharp> | ||
| + | public bool IsDiscPresent { get { return !diskPresenceSensor.Read(); | ||
| + | private Gadgeteer.Interfaces.InterruptInput diskPresenceSensor; | ||
| + | private void SetupDiscPresenceSensor() | ||
| + | char_Display.PrintString(" | ||
| + | diskPresenceSensor = breadBoard_X1.SetupInterruptInput(GT.Socket.Pin.Three, | ||
| + | diskPresenceSensor.Interrupt += diskPresenceSensor_Interrupt; | ||
| + | diskPresenceSensor.Read(); | ||
| + | void diskPresenceSensor_Interrupt(GT.Interfaces.InterruptInput sender, bool value) | ||
| + | char_Display.Clear(); | ||
| + | char_Display.PrintString(IsDiscPresent.ToString()); | ||
| + | I wrote down the documentation on how we hooked up the other sensor. | ||
