| user:tim:start [2014/11/06 18:01] – tim | user:tim:start [2014/12/15 21:57] (current) – tim | ||
| Line 1: | Line 1: | ||
| - | cTimothy | + | Timothy |
| * BOARD MEMBER 5/8/2012 - 5/8/2016 | * BOARD MEMBER 5/8/2012 - 5/8/2016 | ||
| Line 8: | Line 8: | ||
| ====== projects ====== | ====== projects ====== | ||
| * LMN | * LMN | ||
| + | * https:// | ||
| * teardrop " | * teardrop " | ||
| * draw / price in emachineshop | * draw / price in emachineshop | ||
| Line 67: | Line 68: | ||
| * http:// | * http:// | ||
| * [[https:// | * [[https:// | ||
| + | * http:// | ||
| * pointers and arrays: http:// | * pointers and arrays: http:// | ||
| * finish serial support bringup in bailingwire | * finish serial support bringup in bailingwire | ||
| Line 99: | Line 101: | ||
| * HeirloomTech (ThirdCoastCollective? | * HeirloomTech (ThirdCoastCollective? | ||
| + | * create gridbeam https:// | ||
| * check that domain is pointed | * check that domain is pointed | ||
| * set up wordpress | * set up wordpress | ||
| * set up login for rachel to wordpress | * set up login for rachel to wordpress | ||
| - | * build / document gridbeam drill press w/ rachel photographing | + | * build / document |
| - | * welded nut plate for edge of carriage | + | |
| - | * welded clamp bolts / handles | + | |
| - | * welded clamp angle brackets / nuts | + | |
| - | * stepper motor mount | + | |
| - | * hdpe cutting sheet slides | + | |
| - | * leadscrew rests on carriage deck, under clamps | + | |
| * build solar fridge, document and publish, sell kits | * build solar fridge, document and publish, sell kits | ||
| * Find affordable dc compressor | * Find affordable dc compressor | ||
| Line 132: | Line 129: | ||
| - | * prepare for LP C visiting week of 10/20 | ||
| * Seminar in session signs | * Seminar in session signs | ||
| * thisability video - leigh | * thisability video - leigh | ||
| Line 141: | Line 137: | ||
| * https:// | * https:// | ||
| * centralize domains - beacon-center.org, | * centralize domains - beacon-center.org, | ||
| - | * finish | + | * set up apple remote |
| * finish test wordpress plugin for displaying projects in admin interface | * finish test wordpress plugin for displaying projects in admin interface | ||
| * Video Conferencing | * Video Conferencing | ||
| Line 170: | Line 166: | ||
| * send a wordpress theme to smart design | * send a wordpress theme to smart design | ||
| * get videos to jay / do them yourself on the second imac | * get videos to jay / do them yourself on the second imac | ||
| - | * back up nescent data / webpage | ||
| * finish pcard statement | * finish pcard statement | ||
| * evosphere vpn | * evosphere vpn | ||
| * nescent training session resources: http:// | * nescent training session resources: http:// | ||
| - | * recomission mbp w/ ssd | ||
| * investigate graphite logging / graphing framework | * investigate graphite logging / graphing framework | ||
| Line 181: | Line 175: | ||
| * mUVe3D | * mUVe3D | ||
| * SCARA Laser | * SCARA Laser | ||
| - | * spend more time reading about http:// | ||
| - | * http:// | + | * |
| * Home | * Home | ||
| + | * http:// | ||
| + | * http:// | ||
| + | * http:// | ||
| + | * www.changhongbatteries.com/ | ||
| + | * honeywell RTH2300B1012 thermostat [[https:// | ||
| * improve dryer efficiency: http:// | * improve dryer efficiency: http:// | ||
| * solar | * solar | ||
