user:tim:gridbeam_drill_press [2014/11/18 10:10] – timuser:tim:gridbeam_drill_press [2014/11/19 13:22] (current) – tim
-===BOM=== +based on: http://www.openbuilds.com/builds/mini-v-linear-actuator-build.48/
-  * 2x http://openbuildspartstore.com/688z-ball-bearing-8x16x5/ +
-  * 4x http://openbuildspartstore.com/openbuilds-solid-v-wheel-kit/+
-Or (up to 3657mm 12 feet) +===Openbuilds BOM===
-  * $61.14 http://www.mcmaster.com/#perforated-structural-framing-tubing+  * $10 2x http://openbuildspartstore.com/v-slot-actuator-end-mount/
 +  * $13 4x http://openbuildspartstore.com/mini-v-wheel-kit/
 +  * $6 4x http://openbuildspartstore.com/universal-l-brackets/
 +  * $18 1x http://openbuildspartstore.com/nema-17-stepper-motor/
 +  * $7 1x http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pulley-30/
 +  * $5 1x http://openbuildspartstore.com/smooth-idler-pulley-kit/
 +  * $39 3x http://openbuildspartstore.com/v-slot-20-x-40mm/
 +  * $9 1x http://openbuildspartstore.com/mini-v-plate/
 +  * $2 2x http://openbuildspartstore.com/belt-crimp-clamp/
 +  * $1 4x 30mm http://openbuildspartstore.com/m3-cap-head-screws/
 +  * $62.50 (25ft) http://openbuildspartstore.com/gt2-2mm-timing-belt/
 +  * $3 4x http://openbuildspartstore.com/double-tee-nut/
 +  * $2 6mm http://openbuildspartstore.com/socket-head-screws-m3-25-pack/
-Or (up to 1740mm - 5.7 feet) +===Gridbeam BOM===
-  * http://us.misumi-ec.com/vona2/detail/110300071070/?Brand=MSM1 +  * aluminum 1.5" gridbeam
-  * http://us.misumi-ec.com/vona2/detail/110300070820/?Inch=0+  * 1/8 inch x 2 inch perforated aluminum plate
 +  * 90 deg angle stepper motor mount
 +  * 90 deg angle bearing block
 +  * 1/8 inch aluminum plate carriage
 +  * 1/8 inch apeture rollers
 +  * nuts, bolts, spacers for rollers
