| equipment:makerfarm-i3 [2015/09/01 15:18] – zimmer62 | equipment:makerfarm-i3 [2015/09/08 14:01] (current) – zimmer62 | ||
| Line 1: | Line 1: | ||
| ---- datatemplateentry equipment ---- | ---- datatemplateentry equipment ---- | ||
| template | template | ||
| - | picture | + | picture |
| zone : 3D Printing | zone : 3D Printing | ||
| name : Makerfarm Prusa i3 3d Printer | name : Makerfarm Prusa i3 3d Printer | ||
| Line 62: | Line 62: | ||
| * auto bed leveling code | * auto bed leveling code | ||
| * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
| + | * Added the following plugins | ||
| + | * Custom Control Editor | ||
| + | * System Command Editor | ||
| + | * Editor Collection | ||
| + | * EEPROM Marlin Editor | ||
| + | * Print History | ||
| + | * STL Viewer | ||
| + | * Added stub commands to control the lighting | ||
| + | * Currently using M42 P4 S255 / M42 P4 S0 | ||
| + | * We still need a relay hooked up to this pin to drive a light. | ||
| * Still needs done: | * Still needs done: | ||
| * 3D Print an enclosure for the pi | * 3D Print an enclosure for the pi | ||
| Line 81: | Line 91: | ||
| * in parallel to fans | * in parallel to fans | ||
| * in parallel to Motors being energized | * in parallel to Motors being energized | ||
| * Consider all possible scenarios for overheating or loss of control | * Consider all possible scenarios for overheating or loss of control | ||
| * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
