equipment:makerfarm-i3 [2015/08/31 09:22] – zimmer62equipment:makerfarm-i3 [2015/09/08 14:01] (current) – zimmer62
 ---- datatemplateentry equipment ---- ---- datatemplateentry equipment ----
 template      : templates:equipment template      : templates:equipment
-picture       : :equipment:makerfarm-i3:makerfarm_v1.jpg+picture       : :equipment:makerfarm-i3:img_7841.jpg
 zone          : 3D Printing zone          : 3D Printing
 name          : Makerfarm Prusa i3 3d Printer name          : Makerfarm Prusa i3 3d Printer
Line 61: Line 61:
         * beginning and ending Gcode scripts          * beginning and ending Gcode scripts
         * auto bed leveling code         * auto bed leveling code
 +      * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface
 +      * Added the following plugins
 +        * Custom Control Editor
 +        * System Command Editor
 +        * Editor Collection
 +        * EEPROM Marlin Editor
 +        * Print History
 +        * STL Viewer
 +      * Added stub commands to control the lighting
 +        * Currently using M42 P4 S255 / M42 P4 S0
 +          * We still need a relay hooked up to this pin to drive a light.
     * Still needs done:     * Still needs done:
       * 3D Print an enclosure for the pi       * 3D Print an enclosure for the pi
Line 80: Line 91:
             * in parallel to fans             * in parallel to fans
             * in parallel to Motors being energized             * in parallel to Motors being energized
       * Consider all possible scenarios for overheating or loss of control       * Consider all possible scenarios for overheating or loss of control
       * Address the issue of the PSU load which is not connected well and also may overheat nearby objects       * Address the issue of the PSU load which is not connected well and also may overheat nearby objects
 +      * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to.
     * Considerations:     * Considerations:
       * LDAP authentication or equivalent for future https://github.com/foosel/OctoPrint/issues/594       * LDAP authentication or equivalent for future https://github.com/foosel/OctoPrint/issues/594
