| equipment:makerfarm-i3 [2015/08/28 23:19] – mflaga | equipment:makerfarm-i3 [2015/09/08 14:01] (current) – zimmer62 | ||
| Line 1: | Line 1: | ||
| ---- datatemplateentry equipment ---- | ---- datatemplateentry equipment ---- | ||
| template | template | ||
| - | picture | + | picture |
| zone : 3D Printing | zone : 3D Printing | ||
| name : Makerfarm Prusa i3 3d Printer | name : Makerfarm Prusa i3 3d Printer | ||
| Line 57: | Line 57: | ||
| * USB camera has been ordered. | * USB camera has been ordered. | ||
| * Currently is trying Pi-Cam, very slow. | * Currently is trying Pi-Cam, very slow. | ||
| + | * Printer setup modified for | ||
| + | * temperatures | ||
| + | * beginning and ending Gcode scripts | ||
| + | * auto bed leveling code | ||
| + | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
| + | * Added the following plugins | ||
| + | * Custom Control Editor | ||
| + | * System Command Editor | ||
| + | * Editor Collection | ||
| + | * EEPROM Marlin Editor | ||
| + | * Print History | ||
| + | * STL Viewer | ||
| + | * Added stub commands to control the lighting | ||
| + | * Currently using M42 P4 S255 / M42 P4 S0 | ||
| + | * We still need a relay hooked up to this pin to drive a light. | ||
| * Still needs done: | * Still needs done: | ||
| * 3D Print an enclosure for the pi | * 3D Print an enclosure for the pi | ||
| * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | ||
| * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | ||
| - | | + | * More ... |
| - | * temperatures | + | |
| - | * beginning and ending Gcode scripts | + | |
| - | * auto bed leveling code | + | |
| - | * Cura profile | + | |
| * Write instructions on how to connect and print | * Write instructions on how to connect and print | ||
| * Install and test Cura profiles so STL's can be sliced on the machine | * Install and test Cura profiles so STL's can be sliced on the machine | ||
| + | * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts | ||
| + | * If too slow, slice before uploading or consider Raspberry Pi2 | ||
| * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | ||
| * Currently Duct tape and Wire is holding camera. | * Currently Duct tape and Wire is holding camera. | ||
| * Add LED/Lamp for Camera | * Add LED/Lamp for Camera | ||
| * Drive it from Ramps either: | * Drive it from Ramps either: | ||
| - | * in parallel to fans | + | |
| - | * in parallel to Motors being energized | + | * http:// |
| - | * Add a G-Code (there | + | * http:// |
| + | * Other ideas include: | ||
| + | * in parallel to Motors being energized | ||
| + | * Consider all possible scenarios for overheating or loss of control | ||
| + | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
| + | * A backup of the SD card should | ||
| * Considerations: | * Considerations: | ||
| * LDAP authentication or equivalent for future https:// | * LDAP authentication or equivalent for future https:// | ||
