| equipment:makerfarm-i3 [2015/08/26 16:58] – zimmer62 | equipment:makerfarm-i3 [2015/09/08 14:01] (current) – zimmer62 | ||
| Line 1: | Line 1: | ||
| ---- datatemplateentry equipment ---- | ---- datatemplateentry equipment ---- | ||
| template | template | ||
| - | picture | + | picture |
| zone : 3D Printing | zone : 3D Printing | ||
| name : Makerfarm Prusa i3 3d Printer | name : Makerfarm Prusa i3 3d Printer | ||
| Line 31: | Line 31: | ||
| * Octoprint: | * Octoprint: | ||
| * Already done: | * Already done: | ||
| - | * RaspberryPi, | + | * RaspberryPi-B, USB wifi adaptor, SD card have been gathered |
| - | * Octo-Pi has been installed. | + | * apt-get, rasp-config and OctoPrint upgrades have been done. |
| - | * Networking | + | * changed default user/pw of R-Pi. |
| - | * Pi camera has been ordered | + | * set timezone |
| + | * set keyboard to PC104-US | ||
| + | * Network setup with static IP at 10.1.10.221, | ||
| + | * Note, seems OctoPi has FUBAR' | ||
| + | * Setup Port foward for below on ComCast Router. | ||
| + | * 22180-> | ||
| + | * 22144-> | ||
| + | * 22122-> | ||
| + | * Note | ||
| + | * There is no DNS at the space, yet. | ||
| + | * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much. | ||
| + | * Octo-Pi has been installed, | ||
| + | * created users | ||
| + | * some Octo Admin' | ||
| + | * a LMN common user | ||
| + | * enabled Auto login by local network | ||
| + | * any internal 10.1.10.0/ | ||
| + | * Remote or outside will be view only, unless with user/pw. | ||
| + | * enabled auto connect | ||
| + | * Changed Web Page Host name to "LMN MakerFarm i3 Prues" | ||
| + | * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload | ||
| + | * USB camera has been ordered. | ||
| + | * Currently is trying Pi-Cam, very slow. | ||
| + | * Printer setup modified for | ||
| + | * temperatures | ||
| + | * beginning and ending Gcode scripts | ||
| + | * auto bed leveling code | ||
| + | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
| + | * Added the following plugins | ||
| + | * Custom Control Editor | ||
| + | * System Command Editor | ||
| + | * Editor Collection | ||
| + | * EEPROM Marlin Editor | ||
| + | * Print History | ||
| + | * STL Viewer | ||
| + | * Added stub commands to control the lighting | ||
| + | * Currently using M42 P4 S255 / M42 P4 S0 | ||
| + | * We still need a relay hooked up to this pin to drive a light. | ||
| * Still needs done: | * Still needs done: | ||
| - | * Setup network with static IP or DNS at the space | ||
| * 3D Print an enclosure for the pi | * 3D Print an enclosure for the pi | ||
| - | * Add LMN account so people may use this to print | + | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG |
| + | * More ... | ||
| * Write instructions on how to connect and print | * Write instructions on how to connect and print | ||
| * Install and test Cura profiles so STL's can be sliced on the machine | * Install and test Cura profiles so STL's can be sliced on the machine | ||
| + | * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts | ||
| + | * If too slow, slice before uploading or consider Raspberry Pi2 | ||
| * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | ||
| + | * Currently Duct tape and Wire is holding camera. | ||
| + | * Add LED/Lamp for Camera | ||
| + | * Drive it from Ramps either: | ||
| + | * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy | ||
| + | * http:// | ||
| + | * http:// | ||
| + | * Other ideas include: | ||
| + | * in parallel to fans | ||
| + | * in parallel to Motors being energized | ||
| + | * Consider all possible scenarios for overheating or loss of control | ||
| + | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
| + | * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to. | ||
| * Considerations: | * Considerations: | ||
| - | * Publicly accessible IP? or VPN or Proxy, so that you can connect to this device from outside the space. | + | * LDAP authentication |
| - | * If you can connect from outside the space we need to ensure we don't have tons of users connecting at once. Quite possibility a limited number of connections, | + | |
