| equipment:makerfarm-i3 [2015/04/11 16:10] – tim | equipment:makerfarm-i3 [2015/09/08 14:01] (current) – zimmer62 | ||
| Line 1: | Line 1: | ||
| ---- datatemplateentry equipment ---- | ---- datatemplateentry equipment ---- | ||
| template | template | ||
| - | picture | + | picture |
| zone : 3D Printing | zone : 3D Printing | ||
| name : Makerfarm Prusa i3 3d Printer | name : Makerfarm Prusa i3 3d Printer | ||
| Line 8: | Line 8: | ||
| manual | manual | ||
| memberlevel | memberlevel | ||
| - | owner : | + | owner : |
| type : 3D Printer | type : 3D Printer | ||
| status_ | status_ | ||
| Line 15: | Line 15: | ||
| ===Description=== | ===Description=== | ||
| + | Makerfarm 3d printer donated by Craig Pontius | ||
| ===Firmware=== | ===Firmware=== | ||
| https:// | https:// | ||
| Line 27: | Line 27: | ||
| ===Maintenance Log=== | ===Maintenance Log=== | ||
| + | ===Future Enhancements=== | ||
| + | * Octoprint: | ||
| + | * Already done: | ||
| + | * RaspberryPi-B, | ||
| + | * apt-get, rasp-config and OctoPrint upgrades have been done. | ||
| + | * changed default user/pw of R-Pi. | ||
| + | * set timezone | ||
| + | * set keyboard to PC104-US | ||
| + | * Network setup with static IP at 10.1.10.221, | ||
| + | * Note, seems OctoPi has FUBAR' | ||
| + | * Setup Port foward for below on ComCast Router. | ||
| + | * 22180-> | ||
| + | * 22144-> | ||
| + | * 22122-> | ||
| + | * Note | ||
| + | * There is no DNS at the space, yet. | ||
| + | * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much. | ||
| + | * Octo-Pi has been installed, | ||
| + | * created users | ||
| + | * some Octo Admin' | ||
| + | * a LMN common user | ||
| + | * enabled Auto login by local network | ||
| + | * any internal 10.1.10.0/ | ||
| + | * Remote or outside will be view only, unless with user/pw. | ||
| + | * enabled auto connect | ||
| + | * Changed Web Page Host name to "LMN MakerFarm i3 Prues" | ||
| + | * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi. | ||
| + | * USB camera has been ordered. | ||
| + | * Currently is trying Pi-Cam, very slow. | ||
| + | * Printer setup modified for | ||
| + | * temperatures | ||
| + | * beginning and ending Gcode scripts | ||
| + | * auto bed leveling code | ||
| + | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
| + | * Added the following plugins | ||
| + | * Custom Control Editor | ||
| + | * System Command Editor | ||
| + | * Editor Collection | ||
| + | * EEPROM Marlin Editor | ||
| + | * Print History | ||
| + | * STL Viewer | ||
| + | * Added stub commands to control the lighting | ||
| + | * Currently using M42 P4 S255 / M42 P4 S0 | ||
| + | * We still need a relay hooked up to this pin to drive a light. | ||
| + | * Still needs done: | ||
| + | * 3D Print an enclosure for the pi | ||
| + | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | ||
| + | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | ||
| + | * More ... | ||
| + | * Write instructions on how to connect and print | ||
| + | * Install and test Cura profiles so STL's can be sliced on the machine | ||
| + | * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts | ||
| + | * If too slow, slice before uploading or consider Raspberry Pi2 | ||
| + | * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | ||
| + | * Currently Duct tape and Wire is holding camera. | ||
| + | * Add LED/Lamp for Camera | ||
| + | * Drive it from Ramps either: | ||
| + | * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy | ||
| + | * http:// | ||
| + | * http:// | ||
| + | * Other ideas include: | ||
| + | * in parallel to fans | ||
| + | * in parallel to Motors being energized | ||
| + | * Consider all possible scenarios for overheating or loss of control | ||
| + | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
| + | * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to. | ||
| + | * Considerations: | ||
| + | * LDAP authentication or equivalent for future https:// | ||
