equipment:kh7050b-laser_cutter [2016/03/26 18:53] – wrealityequipment:kh7050b-laser_cutter [2017/06/26 19:41] (current) – wreality
Line 37: Line 37:
   * 2015-12-?? E-stop switch replaced after shorting closed   * 2015-12-?? E-stop switch replaced after shorting closed
   * 2016-01-18 E-stop switch replaced after melted contact   * 2016-01-18 E-stop switch replaced after melted contact
-  * 2016-01-?? E-stop switch replaced with rotary switch similar to what the machine shipped with+  * 2016-01-?? Power switch replaced with rotary switch similar to what the machine shipped with
   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.
   * 2016-03-26 Cleaned lens, head mirror, and gantry mirror.  Adjusted/checked alignment.   * 2016-03-26 Cleaned lens, head mirror, and gantry mirror.  Adjusted/checked alignment.
 +  * 2016-10-27 Flourescent worklight tube replace. (22in T5 14W) -- B.Adams
 +  * 2017-06-26 Lenses and mirrors cleaned (all) -- B. Adams
 === Gallery === === Gallery ===
