equipment:kh7050b-laser_cutter [2016/03/26 18:52] – corrected error in previous maint items wrealityequipment:kh7050b-laser_cutter [2017/06/26 19:41] (current) – wreality
Line 31: Line 31:
   * Do not use this machine without training   * Do not use this machine without training
   * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]]   * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]]
-===Maintenance Log==+===Maintenance Log===
   * 2015-10-05 mounted exhaust fan to wall   * 2015-10-05 mounted exhaust fan to wall
   * 2015-10-04 limit switch shimmed   * 2015-10-04 limit switch shimmed
Line 37: Line 37:
   * 2015-12-?? E-stop switch replaced after shorting closed   * 2015-12-?? E-stop switch replaced after shorting closed
   * 2016-01-18 E-stop switch replaced after melted contact   * 2016-01-18 E-stop switch replaced after melted contact
-  * 2016-01-?? E-stop switch replaced with rotary switch similar to what the machine shipped with+  * 2016-01-?? Power switch replaced with rotary switch similar to what the machine shipped with
   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.
   * 2016-03-26 Cleaned lens, head mirror, and gantry mirror.  Adjusted/checked alignment.   * 2016-03-26 Cleaned lens, head mirror, and gantry mirror.  Adjusted/checked alignment.
 +  * 2016-10-27 Flourescent worklight tube replace. (22in T5 14W) -- B.Adams
 +  * 2017-06-26 Lenses and mirrors cleaned (all) -- B. Adams
 === Gallery === === Gallery ===
