| equipment:kh7050b-laser_cutter [2016/02/09 12:10] – wreality | equipment:kh7050b-laser_cutter [2017/06/26 19:41] (current) – wreality | ||
| Line 11: | Line 11: | ||
| type : Laser Cutter # Generic name of the tool (Table Saw vs. 10" Contractor Table Saw) | type : Laser Cutter # Generic name of the tool (Table Saw vs. 10" Contractor Table Saw) | ||
| status_ | status_ | ||
| - | sops | + | sop : https:// |
| checkout : Yes | checkout : Yes | ||
| Line 37: | Line 37: | ||
| * 2015-12-?? E-stop switch replaced after shorting closed | * 2015-12-?? E-stop switch replaced after shorting closed | ||
| * 2016-01-18 E-stop switch replaced after melted contact | * 2016-01-18 E-stop switch replaced after melted contact | ||
| - | * 2016-01-?? | + | * 2016-01-?? |
| * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window. | * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window. | ||
| + | * 2016-03-26 Cleaned lens, head mirror, and gantry mirror. | ||
| + | * 2016-10-27 Flourescent worklight tube replace. (22in T5 14W) -- B.Adams | ||
| + | * 2017-06-26 Lenses and mirrors cleaned (all) -- B. Adams | ||
| === Gallery === | === Gallery === | ||
| Line 53: | Line 56: | ||
| === Links === | === Links === | ||
| - | * [[http:// | + | * [[http:// |
| * [[http:// | * [[http:// | ||
