equipment:jet-band-saw [2013/09/07 20:20] – created wrealityequipment:jet-band-saw [2014/05/10 15:41] (current) – wreality
Line 15: Line 15:
 +A bandsaw uses a blade consisting of a continuous band of metal with teeth along one edge to cut various workpieces. The band rides on two wheels rotating in the same plane. Bandsawing produces uniform cutting action as a result of an evenly distributed tooth load. Bandsaws are used for woodworking, metalworking, or for cutting a variety of other materials. They are particularly useful for cutting irregular or curved shapes, but can make straight cuts. The minimum radius of a curve that can be cut on a particular saw is determined by the width of the band and its kerf.
 +In addition to the [[zones:shop safety rules]] the following should be observed when using this tool.
 +  * Follow the 3” rule from the blade; always keep fingers 3” from the blade.
 +  * Check the blade tension and tracking before starting.
 +  * Don’t cut stock that is not flat on the bottom without a jig.
 +  * Keep a balanced stance at the band saw.
 +  * Never clear small pieces while the blade is moving.
 +  * Never use your thumbs to push toward the blade.
 +  * Never back out of a curve cut while the machine is running.
 +===Useful Links===
 +  * [[http://www.cs.rpi.edu/twiki/pub/RoboticsWeb/WebFacilities/BandsawSafety.pdf|KCWG Bandsaw Safety Rules]]
 ===Contacts for training== ===Contacts for training==
 +Contact [[user:wreality:start|Brian Adams]] or [[user:carlraymond:start|Carl Raymond]] for safety training.
 ===Safety Training=== ===Safety Training===
 +  * Review of machine and shop safety rules.
 +  * Proper procedures for preparing / setup operations.
 +  * Proper operation and control of machine.
 +  * Proper procedures for cleanup.
 +===Maintenance Log==
