equipment:8in-drill-press [2014/05/10 16:04] – wrealityequipment:8in-drill-press [2014/05/22 17:20] (current) – Added belt maintenance wreality
Line 4: Line 4:
 zone          : Machine Shop zone          : Machine Shop
 name          : 8 inch Central Machinery Drill Press name          : 8 inch Central Machinery Drill Press
-manufacturer  : # Central Machinery +manufacturer  : Central Machinery
-model         : # 44506 +model         : 44506
-manual        : # :equipment:44506.pdf +manual        : :equipment:44506.pdf
-memberlevel   : # Full +memberlevel   : Full
-owner         : # Tim Schmidt +owner         : Tim Schmidt
-type          : # Drill Press +type          : Drill Press
-status_       : # Operational+status_       : Operational
 A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically.
Line 37: Line 38:
 ===Maintenance Log=== ===Maintenance Log===
 +  * 5/2014 - [[user:carlraymond:start|Carl Raymond]] replaced the drive belt.
