equipment:8in-drill-press [2014/05/10 16:02] – wrealityequipment:8in-drill-press [2014/05/22 17:20] (current) – Added belt maintenance wreality
Line 2: Line 2:
 template      : templates:equipment template      : templates:equipment
 picture       : :equipment:8in_drill_press.jpg picture       : :equipment:8in_drill_press.jpg
-zone          : Woodshop+zone          : Machine Shop
 name          : 8 inch Central Machinery Drill Press name          : 8 inch Central Machinery Drill Press
 manufacturer  : Central Machinery manufacturer  : Central Machinery
 model         : 44506 model         : 44506
-manual        : equipment:44506.pdf+manual        : :equipment:44506.pdf
 memberlevel   : Full memberlevel   : Full
 owner         : Tim Schmidt owner         : Tim Schmidt
Line 15: Line 15:
 A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically.
Line 37: Line 38:
 ===Maintenance Log=== ===Maintenance Log===
 +  * 5/2014 - [[user:carlraymond:start|Carl Raymond]] replaced the drive belt.
