equipment:lms-cnc-mill [2014/05/09 20:00] wreality created |
equipment:lms-cnc-mill [2017/04/05 00:38] (current) |
Line 34: | Line 34: | ||
+ | In addition to the [[zones:Shop Safety Rules| standard shop safety rules]] for the machine shop: | ||
+ | * Do not make contact with the revolving cutter. | ||
+ | * Place a wooden pad or suitable cover over the table surface to protect it from possible damage. | ||
+ | * Use the buddy system when moving heavy attachments. | ||
+ | * Do not attempt to tighten arbor nuts using machine power. | ||
+ | * When installing or removing milling cutters, always hold them with a rag to prevent cutting your hands. | ||
+ | * While setting up work, install the cutter last to avoid being cut. | ||
+ | * Never adjust the workpiece or work mounting devices when the machine is operating | ||
+ | * Chips should be removed from the workpiece with an appropriate rake and a brush. | ||
+ | * Shut the machine off before making any adjustments or measurements. | ||
+ | * When using cutting oil, prevent splashing by using appropriate splash guards. Cutting oil on the floor can cause a slippery condition that could result in operator injury. | ||
+ | For training contact [[user:carlraymond:start|Carl Raymond]] or [[user:wreality:start|Brian Adams]] | ||
+ | Review the following: | ||
+ | * Proper procedures for securing parts / stock. | ||
+ | * Proper installation of cutting bits/tools. | ||
+ | * Proper operation and control of machine. | ||
+ | * Location, operation, and effect of all machine emergency stops. | ||
+ | ===Maintenance History=== | ||
+ | * 5/2014 -- [[equipment:lms-cnc-mill/tach|Digital Tachometer Installation]] |
