CNC Mill
Status Operational
Zone Machine Shop
Owner Carl Raymond
Tool Type CNC Mill
Member Category Full
User Manual 3960_mini_mil_lusers_guide.pdf
Manufacturer Little Machine Shop
Model LMS-3960
SOPs Link
Checkout Required
barcodeDon't have barcode reader? Click here.
Description
This mill is a CNC conversion of Little Machine Shop's High Torque Mini Mill. It also has the high speed spindle upgrade installed, doubling the max spindle speed to 5000 RPM.
Specifications
End Milling Capacity 0.6“ (16 mm)
Face Milling Capacity 1.2” (30 mm)
Drilling Capacity 0.5“ (13 mm)
Table Size 18.1” x 4.7“ (460 mm x 120 mm)
X-Axis Travel 11.8” (300 mm)
Y-Axis Travel 5.1“ (130 mm)
Z-Axis Travel 9.8” (250 mm)
Throat 6.5“ (165 mm)
Head Tilt None
Spindle Taper R8
Spindle Motor 0.67 hp (500 Watts)
Spindle Speed 200 - 5000 RPM
Safety Rules
In addition to the standard shop safety rules for the machine shop:
  • Do not make contact with the revolving cutter.
  • Place a wooden pad or suitable cover over the table surface to protect it from possible damage.
  • Use the buddy system when moving heavy attachments.
  • Do not attempt to tighten arbor nuts using machine power.
  • When installing or removing milling cutters, always hold them with a rag to prevent cutting your hands.
  • While setting up work, install the cutter last to avoid being cut.
  • Never adjust the workpiece or work mounting devices when the machine is operating
  • Chips should be removed from the workpiece with an appropriate rake and a brush.
  • Shut the machine off before making any adjustments or measurements.
  • When using cutting oil, prevent splashing by using appropriate splash guards. Cutting oil on the floor can cause a slippery condition that could result in operator injury.
Contacts for training
For training contact Carl Raymond or Brian Adams
Safety Training
Review the following:
  • Review of machine and shop safety rules.
  • Proper procedures for securing parts / stock.
  • Proper installation of cutting bits/tools.
  • Proper operation and control of machine.
  • Location, operation, and effect of all machine emergency stops.
  • Proper procedures for cleanup.
Maintenance History
