| user:zimmer62:projects:cherrypi-iii-build [2015/05/23 03:46] – zimmer62 | user:zimmer62:projects:cherrypi-iii-build [2017/04/05 00:38] (current) – external edit 127.0.0.1 | ||
| Line 3: | Line 3: | ||
| * 5/ | * 5/ | ||
| * Printed [[http:// | * Printed [[http:// | ||
| + | * [[http:// | ||
| * Printed 4x [[http:// | * Printed 4x [[http:// | ||
| * Chose to print 4, so I'd have a spare, and because it lined up nicely on the plate (probably a wasted part) | * Chose to print 4, so I'd have a spare, and because it lined up nicely on the plate (probably a wasted part) | ||
| Line 13: | Line 14: | ||
| * 5/21/2015 Some parts started to arrive, such as stepper motors and some screws and nuts. | * 5/21/2015 Some parts started to arrive, such as stepper motors and some screws and nuts. | ||
| * 5/20/2015 3D printed parts for base. | * 5/20/2015 3D printed parts for base. | ||
| * 5/19/2015 Tried acetone vapor bath just fro the heck of it. | * 5/19/2015 Tried acetone vapor bath just fro the heck of it. | ||
| Line 20: | Line 23: | ||
| * 5/18/2015 Start of the Cherry Pi III project | * 5/18/2015 Start of the Cherry Pi III project | ||
| - | * Ordered Many Many parts online | + | * Ordered Many Many parts online |
| Line 29: | Line 32: | ||
| * http:// | * http:// | ||
| + | Extruder: | ||
| Tim recomended the [[http:// | Tim recomended the [[http:// | ||
| - | Many parts were sourced from eBay, Amazon, or openbuilds.com | + | |
| I like this [[http:// | I like this [[http:// | ||
| Line 37: | Line 41: | ||
| Interesting ideas | Interesting ideas | ||
| the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/ | the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/ | ||
| Line 43: | Line 46: | ||
| tips... fan motor not spinning | tips... fan motor not spinning | ||
| If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi. | If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi. | ||
| + | Slicing | ||
| Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height. | Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height. | ||
| - | It appears a different size carriage will be needed for the v-slot extrusions | + | I have been using slic3r with a .3mm layer height and a 20% infill. |
| - | http:// | + | ---- |
| + | Notes: | ||
| + | It appears a different size carriage will be needed for the v-slot extrusions: | ||
| + | [[http:// | ||
| http:// | http:// | ||
