equipment:wishlist:laser_cutter [2015/08/05 19:25] zimmer62 created |
equipment:wishlist:laser_cutter [2017/04/05 00:38] (current) |
- | New Laser Cutter | + | ---- |
+ | ======= Status: ======= | ||
+ | Laser cutter has been purchased and delivered. **The information below is for archive purposes** | ||
+ | ======= New Laser Cutter Working Group ======= | ||
+ | ==== Mission: ==== | ||
+ | To research and recommend an additional laser cutter to be purchased by LMN. | ||
+ | === Working Group Members: === | ||
+ | * [[user:zimmer62:start|Joe Zimmerman]] | ||
+ | * [[user:zik:start|Ed Symanzik]] | ||
+ | * [[user:wreality:start|Brian Adams]] | ||
+ | === Considerations: === | ||
+ | * The new laser cutter should be able to be shipped to LMN within a reasonable time frame | ||
+ | * Fibre lasers do not cut wood: http://www.engraversjournal.com/article.php/2743/index.html | ||
+ | === Questions that need to be addressed: === | ||
+ | (Educated guesses are okay here) | ||
+ | - What kind of materials and how thick can we cut with: | ||
+ | * 60 Watt cutter | ||
+ | * 80 Watt cutter | ||
+ | - What kind of infrastructure improvements will this need? | ||
+ | * Power | ||
+ | * Venting | ||
+ | - What can we expect for support? | ||
+ | * Will it be supported by an ebay distributor? | ||
+ | * Will we need a Chinese speaker? | ||
+ | - What software will we need? | ||
+ | * Some of these cutters list several supported graphics formats but not gcode. | ||
+ | * How do we mix cutting and engraving? | ||
+ | * Will we also need to purchase AutoCAD or the like? | ||
+ | - Keep in mind the weight and door size if we get a larger laser. | ||
+ | === Items to research: === | ||
+ | * Ebay Laser Cutters | ||
+ | * Do any of these have forum followings such as the K40 does? | ||
+ | === Budget: === | ||
+ | * $2500, of which 50% needs to be raised in new donations. | ||
+ | * Any funds raised in excess of the 50% match will increase the Equipment Purchase line item, for the purpose of purchasing the laser. | ||
+ | === Fund Raising: === | ||
+ | * FIXME Ideas are needed here | ||
+ | === Links: === | ||
+ | * http://www.ebay.com/itm/110V-60W-USB-Laser-Engraving-Cutting-Machine-Laser-Engraver-Cutter-CE-FDA-/161688742870?hash=item25a5666bd6 | ||
+ | === To Do: === | ||
+ | * Create a Grid on this wiki with links, prices, wattage, cutting size, and additional notes. |
