equipment:wishlist:laser_cutter [2015/08/09 20:19] zik |
equipment:wishlist:laser_cutter [2017/04/05 00:38] (current) |
+ | ======= Status: ======= | ||
+ | Laser cutter has been purchased and delivered. **The information below is for archive purposes** | ||
======= New Laser Cutter Working Group ======= | ======= New Laser Cutter Working Group ======= | ||
Line 5: | Line 16: | ||
=== Working Group Members: === | === Working Group Members: === | ||
* [[user:zimmer62:start|Joe Zimmerman]] | * [[user:zimmer62:start|Joe Zimmerman]] | ||
* [[user:zik:start|Ed Symanzik]] | * [[user:zik:start|Ed Symanzik]] | ||
+ | * [[user:wreality:start|Brian Adams]] | ||
Line 23: | Line 37: | ||
* The new laser cutter should be able to be shipped to LMN within a reasonable time frame | * The new laser cutter should be able to be shipped to LMN within a reasonable time frame | ||
+ | * Fibre lasers do not cut wood: http://www.engraversjournal.com/article.php/2743/index.html | ||
Line 42: | Line 56: | ||
* How do we mix cutting and engraving? | * How do we mix cutting and engraving? | ||
* Will we also need to purchase AutoCAD or the like? | * Will we also need to purchase AutoCAD or the like? | ||
+ | - Keep in mind the weight and door size if we get a larger laser. | ||
Line 51: | Line 66: | ||
- | === Budget: === | + | === Budget: === |
- | * It was suggested that $1300 could be paid for by LMN (gut feeling from Carl) | + | * $2500, of which 50% needs to be raised in new donations. |
- | * Other possible donations could get an additional $1100 fairly easily. | + | * Any funds raised in excess of the 50% match will increase the Equipment Purchase line item, for the purpose of purchasing the laser. |
+ | === Fund Raising: === | ||
+ | * FIXME Ideas are needed here | ||
