equipment:uscutter_lp_24 [2014/05/14 04:18] wreality created |
equipment:uscutter_lp_24 [2015/01/20 22:48] voidptr |
+ | ~~NOTOC~~ | ||
Line 15: | Line 17: | ||
+ | Makes really big and or small stickers | ||
- | * Rose Canino-King | + | * Rose Canino-Koning |
* Brian Adams | * Brian Adams | ||
* Nick Kwiatkowski | * Nick Kwiatkowski | ||
* Joe Zimmerman | * Joe Zimmerman | ||
- | ===Maintenance Log=== | + | ==== Specifications ==== |
+ | 24 in wide cutter | ||
+ | ==== Workflow ==== | ||
+ | - import vector drawing | ||
+ | - ensure the image is a vector. | ||
+ | - If not see manuals section "Converting a Raster Image to Vector Image" | ||
+ | - select cut | ||
+ | - select finish | ||
+ | ==== Software & Drivers ==== | ||
+ | In short... | ||
+ | Install "SignBlazer Elements for USCutter" | ||
+ | The interface to the LaserPoint24 is Serial. The LP24 has both a DB9 or USB. Where the USB will install as a FDTI and should auto install. If needed drivers are available at http://support.uscutter.com/index.php?/Knowledgebase/List/Index/39 | ||
+ | SignBlazer is a free design and cutting utility for Windows O/S only. It suits the needs of many customers but lacks much of the power and functionality of true design programs such as,CorelDraw or Inkscape (inkscape.org). The official release of SignBlazer only works in "Trial Mode" but it is fully functional. It also does not require an activation code of any kind; nor do you need to register or update it because it is no longer being developed. | ||
+ | http://support.uscutter.com/index.php?/Knowledgebase/Article/View/190/27/01-signblazer-elements | ||
+ | ==== Consumables ==== | ||
+ | Rolls of vinyl | ||
+ | ==== Tutorials ==== | ||
+ | Google it | ||
+ | Actually read the following sections of the manual, they are quite short and straight forward. | ||
+ | * "Selecting a Location for Your Cutter" | ||
+ | * "Starting SignBlazer" | ||
+ | ==== Maintenance ==== | ||
+ | Keep it clean | ||
+ | ==== Resources ==== | ||
+ | http://support.uscutter.com/index.php?/Knowledgebase/List/Index/61/laserpoint |
