equipment:rostock [2015/08/17 17:28] zimmer62 |
equipment:rostock [2017/04/05 00:38] (current) |
- | picture : # image to use for the tool (don't forget to include namespace if needed) | + | picture : :equipment:rostock:img_7844.jpg # image to use for the tool (don't forget to include namespace if needed) |
zone : 3D Printing # zone (Woodshop, Machine Shop, Electronics, Crafting, etc) (will be converted to a link to the zone) | zone : 3D Printing # zone (Woodshop, Machine Shop, Electronics, Crafting, etc) (will be converted to a link to the zone) | ||
name : Rostock 3D Printer# Descriptive name for the tool | name : Rostock 3D Printer# Descriptive name for the tool | ||
Line 15: | Line 15: | ||
- | Rostock printer build and donated by Randy Schott. | + | Rostock printer built and donated by Randy Schott. |
- | Currently needs some attention. | + | It currently needs some attention to get it printing well. |
Here are facts we know about the current state of this printer | Here are facts we know about the current state of this printer | ||
Line 23: | Line 23: | ||
* Not happy with the arms | * Not happy with the arms | ||
* Printing things well only if they were round, like a vase. | * Printing things well only if they were round, like a vase. | ||
- | * Running Repetier Firmward v0.82 | + | * Running Repetier Firmware v0.82 |
* The plans Randy used to build the printer were from Richrap's blog. | * The plans Randy used to build the printer were from Richrap's blog. | ||
* http://richrap.blogspot.com/2013/04/rostock-delta-3d-printer-build.html | * http://richrap.blogspot.com/2013/04/rostock-delta-3d-printer-build.html | ||
Line 34: | Line 34: | ||
* Jerry and I noticed one of the top ends that are clamped to the vertical rods slipped up and down a little bit changing the tension on that belt. We need to check the tightness of this | * Jerry and I noticed one of the top ends that are clamped to the vertical rods slipped up and down a little bit changing the tension on that belt. We need to check the tightness of this | ||
* Calibration will be needed. | * Calibration will be needed. | ||
- | * If we can get firmware settings from Randy. | + | * Firmware settings from Randy, or identify all needed values for new firmware settings. |
* The fan on the power supply was not spinning, I'm not sure if that is a problem since we did not draw much current from the power supply during our tests, but it should be verified that the fan is in fact working, but limited to turns itself on when needed. | * The fan on the power supply was not spinning, I'm not sure if that is a problem since we did not draw much current from the power supply during our tests, but it should be verified that the fan is in fact working, but limited to turns itself on when needed. | ||
- | Stuff that should be upgrade at some point | + | Stuff that should be upgraded at some point |
- | * Auto bed leveling | + | * Add auto bed leveling |
* Jerry suggested it would be nice to have the LCD turned up at an angle so you could see it. I think making it adjustable would be ideal. I'm betting there is a thingiverse part designed for exactly this. | * Jerry suggested it would be nice to have the LCD turned up at an angle so you could see it. I think making it adjustable would be ideal. I'm betting there is a thingiverse part designed for exactly this. | ||
- | * Updated firmware to v0.92 | + | * Maybe this? http://www.thingiverse.com/thing:361089 |
+ | * Update firmware to v0.92 (or newer or non repetier) | ||
* http://www.repetier.com/firmware/v092/index.html If you pick delta, it helps with measuring arms etc. | * http://www.repetier.com/firmware/v092/index.html If you pick delta, it helps with measuring arms etc. | ||
* The screw's that hold the arduino and ramps board to the base are not designed ideally since you need to remove the bed to easily remove one of the screws. If given the chance in the future we should replace the screws with standoffs or another solution that doesn't require removing the bed to turn a screw, maybe a trapped nut under the bed. | * The screw's that hold the arduino and ramps board to the base are not designed ideally since you need to remove the bed to easily remove one of the screws. If given the chance in the future we should replace the screws with standoffs or another solution that doesn't require removing the bed to turn a screw, maybe a trapped nut under the bed. |
