zones:3d_printing_area [2014/12/03 18:51] jfahner3 |
zones:3d_printing_area [2017/04/05 00:38] |
- | {{ :zones:top_floor.png?direct |}} | ||
- | FIXME Have an idea or status update for this page? Please add it! FIXME | ||
- | ===About=== | ||
- | The 3D Printing Area is located on the top floor of Lansing Makers Network. | ||
- | ===Stewards=== | ||
- | Zone Steward: [[user:tim:start|Tim Schmidt]] | ||
- | ===3D Printing Zone Tools / Equipment=== | ||
- | ---- datatemplatelist ---- | ||
- | template: templates:equipment_list | ||
- | cols : %pageid%, name, status_, picture | ||
- | headers : %pageid%, name, status_, picture | ||
- | filter : zone=3D Printing | ||
- | ===Goals=== | ||
- | * promote the use of 3D printing technologies within the makerspace - software, hardware, and 3D printed products | ||
- | * showcase the makerspace's 3D printing | ||
- | ===Plan=== | ||
- | * collect / adapt / develop a training curriculum | ||
- | * inventory and document printers on this page, linking to firmware, modified parts, etc. | ||
- | * create real-life FIXME tags, with a spot to write-in the issue, and a way to affix them to an item | ||
- | * organize group-purchase filament orders | ||
- | * establish a regular meeting schedule | ||
- | * establish LMN-purchased stock, which can be paid for per-print via Cura / Repetier cost estimation | ||
- | * purchase / install fast-heating bed heaters on all printers: http://www.ebay.com/itm/like/191353869307?lpid=82 | ||
- | * maintain two or more working 3D printers at all times. | ||
- | ===Ongoing Projects=== | ||
- | * 3D print a buildlog.net laser cutter rotational axis: http://www.buildlog.net/blog/2011/04/open-source-rotational-adapter-part-1/ | ||
- | * Progress: not started | ||
- | * FIXME (unclaimed): download the assembly STEP file, and export each printed part into an STL http://www.buildlog.net/wiki/doku.php?id=rotational | ||
- | * FIXME (unclaimed): print parts | ||
- | * FIXME (unclaimed): assemble and install in laser, connect motor to electronics | ||
- | * FIXME (unclaimed): modify laser cutter firmware for rotational axis | ||
- | * Get the Makerfarm printing reliably | ||
- | * Progress: Hot end installed and tested. Extruding works! | ||
- | - Question: New hot end topped out at 206 degrees, is that a firmware issue? | ||
- | * Progress: Jerry Fahner: Longer (blue) probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK. | ||
- | * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y. | ||
- | * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help. | ||
- | * Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container. | ||
- | * Refurbish the solidoodle 2 3D printer | ||
- | * Looking for someone to help with the completion of this project. | ||
- | * Progress: [[user:zimmer62:start|Joe Zimmerman]] has started another design for laser-cut base to contain power supply, MEGA / Ramps, Solid State Relay, Terminal Block etc. A mount for the electronics, and LCD also needs to be created, possibly into the front of the base. | ||
- | * FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic? | ||
- | * FIXME (unclaimed): install power supply, electronics, LCD | ||
- | * FIXME (claimed): run motor and hotend wiring | ||
- | - A crimper and ends to put new ends on the motors and existing wiring are at the space. | ||
- | - The fan will need a DC-DC power step down converter which is on hand at the space, but needs to be set for 12volts | ||
- | * FIXME (unclaimed): laser cut improved magnetic side walls | ||
- | * Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer | ||
- | * Progress: Collecting parts | ||
- | * FIXME (unclaimed): print two motor brackets | ||
- | * FIXME (unclaimed): pull 3 NEMA-23 motors from the parts area | ||
- | * FIXME (unclaimed): acquire makerslide | ||
- | * Improve the frame of the Rostock by replacing it's MDF with aluminum extrusion. Some 3D printed parts may need to be replaced. | ||
- | * Progress: establish bill of materials | ||
- | * FIXME (unclaimed): print http://www.thingiverse.com/thing:516447/ | ||
