zones:3d_printing_area [2014/12/03 18:33]
jfahner3
zones:3d_printing_area [2016/01/28 18:29]
wreality Fixed some outdated info.
Line 3: Line 3:
 ===About=== ===About===
-The 3D Printing Area is located on the top floor of Lansing Makers Network.+3D printers live here.
 ===Stewards=== ===Stewards===
-Zone Steward: ​[[user:tim:start|Tim Schmidt]]+Zone Steward: :ORPHANED:
 ===3D Printing Zone Tools / Equipment=== ===3D Printing Zone Tools / Equipment===
Line 40: Line 40:
     * Progress: Hot end installed and tested. ​ Extruding works!     * Progress: Hot end installed and tested. ​ Extruding works!
       - Question: New hot end topped out at 206 degrees, is that a firmware issue?       - Question: New hot end topped out at 206 degrees, is that a firmware issue?
-    * Progress: Jerry Fahner:​Longer probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. +    * Progress: Jerry Fahner: Longer ​(blue) ​probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK
-    * FIXME (unclaimed):​ Some tuning needed with y-stop.  +    * FIXME (unclaimed):​ Some tuning needed with Y-stop. The test print caused chatter when homing Y
-    * FIXME (unclaimed) : Fan overcools ​hot end. A piece of tape on fan helped but a shroud is needed.+    * FIXME (unclaimed):​ Fan over-cools ​hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help.
     * Progress: [[user:​zimmer62:​start|Joe Zimmerman]]:​ soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container.     * Progress: [[user:​zimmer62:​start|Joe Zimmerman]]:​ soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container.
   * Refurbish the solidoodle 2 3D printer   * Refurbish the solidoodle 2 3D printer
