zones:3d_printing_area [2014/11/09 23:54] zimmer62 |
zones:3d_printing_area [2014/12/03 18:51] jfahner3 |
Line 40: | Line 40: | ||
- Question: New hot end topped out at 206 degrees, is that a firmware issue? | - Question: New hot end topped out at 206 degrees, is that a firmware issue? | ||
- | * Progress: Extra long probe arms printed in case they are needed - laying near printer | + | * Progress: Jerry Fahner: Longer (blue) probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK. |
- | * [[user:tim:start|Tim Schmidt]]: determine the offset between nozzle and bed leveling probe, and update the printer's wiki page. | + | * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y. |
- | * [[user:tim:start|Tim Schmidt]]: configure and install updated firmware | + | * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help. |
- | * [[user:tim:start|Tim Schmidt]]: test printing | + | |
* Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container. | * Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container. | ||
* Refurbish the solidoodle 2 3D printer | * Refurbish the solidoodle 2 3D printer |
