zones:3d_printing_area [2014/11/06 14:40] jfahner3 |
zones:3d_printing_area [2014/12/03 18:51] jfahner3 |
Line 39: | Line 39: | ||
* Get the Makerfarm printing reliably | * Get the Makerfarm printing reliably | ||
- | * Progress: Extra long probe arms printed in case they are needed - laying near printer | + | - Question: New hot end topped out at 206 degrees, is that a firmware issue? |
- | * [[user:tim:start|Tim Schmidt]]: determine the offset between nozzle and bed leveling probe, and update the printer's wiki page. | + | * Progress: Jerry Fahner: Longer (blue) probe arm installed, arm angles and offsets determined, firmware reflashed, test print completed. Standard MakerFarm thermister table used but seems to work OK. |
- | * [[user:tim:start|Tim Schmidt]]: configure and install updated firmware | + | * FIXME (unclaimed): Some tuning needed with Y-stop. The test print caused chatter when homing Y. |
- | * [[user:tim:start|Tim Schmidt]]: test printing | + | * FIXME (unclaimed): Fan over-cools hot end. A piece of tape on fan helped but a shroud is needed. Reversing fan may help. |
- | * FIXME (unclaimed): soak magma hotend in acetone - it's already disassembled and in the glass container. | + | * Progress: [[user:zimmer62:start|Joe Zimmerman]]: soaked magma hotend in acetone, cleaned with fire, polished and is soaking again in the glass container. |
* Refurbish the solidoodle 2 3D printer | * Refurbish the solidoodle 2 3D printer | ||
* Looking for someone to help with the completion of this project. | * Looking for someone to help with the completion of this project. | ||
- | * Progress: Joe Zimmerman had a design for laser-cut base to contain power supply. This design never worked out, at the moment the design was scrapped. A mount for the electronics, and LCD also needs to be created | + | * Progress: [[user:zimmer62:start|Joe Zimmerman]] has started another design for laser-cut base to contain power supply, MEGA / Ramps, Solid State Relay, Terminal Block etc. A mount for the electronics, and LCD also needs to be created, possibly into the front of the base. |
* FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic? | * FIXME (unclaimed): laser cut a test to verify that the dimensions are correct, then laser cut the final version - ply? acrylic? | ||
* FIXME (unclaimed): install power supply, electronics, LCD | * FIXME (unclaimed): install power supply, electronics, LCD | ||
* FIXME (claimed): run motor and hotend wiring | * FIXME (claimed): run motor and hotend wiring | ||
- | - A crimper and ends have been ordered and received to put new ends on the motors and existing wiring. | + | - A crimper and ends to put new ends on the motors and existing wiring are at the space. |
- | - The fan will need a DC-DC power step down converter which is on hand, but needs to be set for 12volts | + | - The fan will need a DC-DC power step down converter which is on hand at the space, but needs to be set for 12volts |
* FIXME (unclaimed): laser cut improved magnetic side walls | * FIXME (unclaimed): laser cut improved magnetic side walls | ||
* Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer | * Build a [[https://wolfmanjm.github.io/wolfstock/ | Wolfstock]] extra-large Delta 3D printer |
