user:zimmer62:projects:cherrypi-iii-build [2015/05/22 18:05] zimmer62 |
user:zimmer62:projects:cherrypi-iii-build [2017/04/05 00:38] (current) |
I would like to build a Cherry Pi III "ish" delta printer. I will use many of the parts and idea from [[http://forums.reprap.org/read.php?178,361141|this forum]]. And [[http://www.thingiverse.com/thing:344408|this thingiverse page]]. | I would like to build a Cherry Pi III "ish" delta printer. I will use many of the parts and idea from [[http://forums.reprap.org/read.php?178,361141|this forum]]. And [[http://www.thingiverse.com/thing:344408|this thingiverse page]]. | ||
- | * 5/18/2015 Start of the Cherry Pi III project | + | * 5/22/2015 |
- | * 5/18/2015 Disc's for spool printed. | + | * Printed [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]] |
- | {{:user:zimmer62:projects:spool_disk_1.jpg?direct&200|}} | + | * [[http://youtu.be/ziopiy626Cs]] Here is a timelapse of these parts |
+ | * Printed 4x [[http://www.thingiverse.com/thing:487476|Mini V Wheel Carriage for OpenBuild Extrusions]] | ||
+ | * Chose to print 4, so I'd have a spare, and because it lined up nicely on the plate (probably a wasted part) | ||
+ | * Aluminum Extrusion, and Mini V-Wheel kits showed arrived from OpenBuild | ||
+ | * Tested AstroBox / AstroPrint. My thoughts are to currently avoid this | ||
+ | * The setup and web ui were very nice. | ||
+ | * It doesn't support streaming video which is a deal breaker. | ||
+ | * It can talk to your machine from the cloud, no obvious way to turn that off | ||
+ | * Raspberry Pi camera is not supported | ||
+ | * 5/21/2015 Some parts started to arrive, such as stepper motors and some screws and nuts. | ||
+ | * 5/20/2015 3D printed parts for base. | ||
+ | {{:user:zimmer62:projects:parts_as_of_may_20.jpg?direct&200|}} | ||
* 5/19/2015 Tried acetone vapor bath just fro the heck of it. | * 5/19/2015 Tried acetone vapor bath just fro the heck of it. | ||
{{:user:zimmer62:projects:spool_disk_2.jpg?direct&200|}} | {{:user:zimmer62:projects:spool_disk_2.jpg?direct&200|}} | ||
+ | * 5/18/2015 Disc's for spool printed. | ||
+ | {{:user:zimmer62:projects:spool_disk_1.jpg?direct&200|}} | ||
+ | * 5/18/2015 Start of the Cherry Pi III project | ||
+ | * Ordered Many Many parts online most were sourced from eBay, Amazon, or openbuilds.com | ||
- | * 5/20/2015 3D printed parts for base. | + | |
Sourcing a few parts have been difficult | Sourcing a few parts have been difficult | ||
* Magnetic balls | * Magnetic balls | ||
- | * * http://www.magnet4less.com/ need to figure out what to order | + | * http://www.magnet4less.com/ need to figure out what to order |
+ | Extruder: | ||
Tim recomended the [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]] | Tim recomended the [[http://www.thingiverse.com/thing:126778|Airtripper Bowden Extruder BSP Edition]] | ||
- | Many parts were sourced from eBay, Amazon, or openbuilds.com | + | |
I like this [[http://www.thingiverse.com/thing:651472|Lightweight end effector plate for Delta]] But it would need various modifications depending on what we attach to it. | I like this [[http://www.thingiverse.com/thing:651472|Lightweight end effector plate for Delta]] But it would need various modifications depending on what we attach to it. | ||
Line 24: | Line 41: | ||
Interesting ideas | Interesting ideas | ||
* http://www.spiderbot.eu/en/technology/tss-three-sphere-system.html | * http://www.spiderbot.eu/en/technology/tss-three-sphere-system.html | ||
the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/specified length) x delta rod length = new delta rod length | the adjustment you need to make for size of parts (once you have your Z correct) is the delta rod length. You can use Rich's M666 command for that. The formula is (measured length/specified length) x delta rod length = new delta rod length | ||
Line 30: | Line 46: | ||
tips... fan motor not spinning | tips... fan motor not spinning | ||
If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi. | If you rotate the magnets you will find a 'sweet spot' where they don't cause this issue. I had the same problem on the original Cherry Pi. | ||
+ | Slicing | ||
Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height. | Andy: I use 0.3mm layer height and 33% in fill on virtually all my printed parts. The effector, which is the only ABS part, I print at 0.2mm layer height. | ||
+ | I have been using slic3r with a .3mm layer height and a 20% infill. I've been printing all parts in ABS | ||
+ | Notes: | ||
+ | It appears a different size carriage will be needed for the v-slot extrusions: | ||
+ | [[http://www.thingiverse.com/thing:487476|Mini V Wheel Carriage for OpenBuild Extrusions]] | ||
+ | http://forums.reprap.org/read.php?178,361141,page=17 This page here has someones build log where we can see how it's assembled | ||
