user:zimmer62:autodvdloaderrobot:start [2013/09/30 13:47] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2017/04/05 00:38] (current) |
Line 18: | Line 18: | ||
* Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
* Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
* Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
* Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E) | * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E) | ||
Line 23: | Line 27: | ||
* Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | ||
- | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] | + | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] (1.8 degrees 1.2A) |
- | * 1.8 degrees 1.2A | + | * Rated Voltage = 4V |
Line 59: | Line 71: | ||
TODO: | TODO: | ||
- | * Find datasheet for stepper motor in machine | ||
- | * Interface both types of optical sensors to gadgeteer board | + | * Verify resistors and voltage coming into micro-controller. |
* Write some rough code to exercise the machine using the optical sensors to prevent damage | * Write some rough code to exercise the machine using the optical sensors to prevent damage | ||
* A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | ||
Line 68: | Line 79: | ||
+ | 9/30/2013 | ||
+ | * Red Wire to 5V | ||
+ | <code csharp> | ||
+ | </code> | ||
