user:zimmer62:autodvdloaderrobot:start [2013/09/30 13:47] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2017/04/05 00:38] |
- | {{:user:zimmer62:autodvdloaderrobot:t2ec16vhjggffm6uqjkpbriypkfvuw_60_57.jpg?direct&300|}} | ||
- | This started out as an iRippit X-50 50 Disc CD/DVD Duplicator. I saw it on a deal site and figured I could hack it to get it to read CD's / DVD's instead of burn them. I'm not interested in copying disc's I just want an easy way to auto load them for ripping to my NAS. | ||
- | At one point, I had a majority of my DVD's ripped to my Windows Home Server. The hard drives in that ended up failing without much warning, and I lost a good chunk of that collection. I still own the optical disc's and would like to re-rip them, but in an automatic way. | ||
- | Drivers for newer operating systems are not there, and the software this works with is really only designed to copy a bunch of the same disc over and over. A band interesting in burning their own discs might like this. | ||
- | The first step was to remove all of the housing and electronics, and identify what things I can use and what each part is. | ||
- | {{:user:zimmer62:autodvdloaderrobot:img_6752.jpg?direct&800|}} | ||
- | {{:user:zimmer62:autodvdloaderrobot:img_6762.jpg?direct&800|}} | ||
- | I documented what I could figure out from each connecting wire: | ||
- | * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
- | * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
- | * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
- | * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E) | ||
- | * Disk Present (Red, Black, Blue) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Blue = E) | ||
- | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | ||
- | * JP13 Greyish White Wires go to the Disc Release Solenoid. | ||
- | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] | ||
- | * 1.8 degrees 1.2A | ||
- | * Power Supply 12V @ 2.5A | ||
- | This should be enough information to get going. | ||
- | I don't need the safety interrupt, so that leaves me with 5 sensors, 1 stepper and 1 solenoid that I need to interface with. | ||
- | {{:user:zimmer62:autodvdloaderrobot:img_6756.jpg?direct&800| }} | ||
- | That still left me with trying to identify that Sharp optical sensor since there are 2 of them I will need. | ||
- | I can see that the blue wire here is the Emitter, I'd really like to find the specs on this to make sure I drive it correctly. | ||
- | My search let me [[http://memakingthings.blogspot.com/2012/12/optical-interrupters.html|here]], not identical, but very close. The 361 chip on my board is a current limiting resistor. | ||
- | A little experimenting with the lid sensor that I'm not going to need should help me figure out how to interface with this. | ||
- | Ohhh I found it [[http://www.digikey.com/product-detail/en/GP1A75E3J00F/425-2565-ND/857214|@ DigiKey 425-2565-ND]] | ||
- | [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] I'm still not sure from this how to identify the other two leads. | ||
- | I had a heck of a time getting the .net gadgeteer board and the L6470 stepper controller to talk to any stepper motor. | ||
- | I was finally able to get this turning a stepper motor over the weekend. It seems it's very sensitive to it's register settings. | ||
- | I had to use some software and a stepper motor datasheet to get some values to feed into their software. | ||
- | According to this: | ||
- | https://www.ghielectronics.com/community/forum/topic?id=8081&page=2 | ||
- | Those values only get you close and you need to use an o-scope to tune it further. | ||
- | TODO: | ||
- | * Find datasheet for stepper motor in machine | ||
- | * Hookup and test stepper motor to L6470 module | ||
- | * Interface both types of optical sensors to gadgeteer board | ||
- | * Write some rough code to exercise the machine using the optical sensors to prevent damage | ||
- | * A loop that grabs CD's from source stack, drops them every other into the bins until bins are full. | ||
- | * Write code to interface machine to PC to take simple commands and report back | ||
- | * Write code on PC side to control machine and rip discs | ||
