user:zimmer62:autodvdloaderrobot:start [2013/09/21 16:46] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2013/10/01 02:08] zimmer62 |
Line 23: | Line 23: | ||
* Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | ||
- | * Stepper Motor FL42STH47-1206AC | + | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] (1.8 degrees 1.2A) |
- | * 1.8 degrees 1.2A | + | * Rated Voltage = 4V |
Line 45: | Line 53: | ||
[[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] I'm still not sure from this how to identify the other two leads. | [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] I'm still not sure from this how to identify the other two leads. | ||
+ | According to this: | ||
+ | TODO: | ||
+ | 9/30/2013 | ||
+ | * Red Wire to 5V | ||
+ | <code csharp> | ||
+ | </code> | ||
