user:zimmer62:autodvdloaderrobot:start [2013/09/21 16:46] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2013/09/30 13:56] zimmer62 |
Line 23: | Line 23: | ||
* Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | ||
- | * Stepper Motor FL42STH47-1206AC | + | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] (1.8 degrees 1.2A) |
- | * 1.8 degrees 1.2A | + | * Rated Voltage = 4V |
Line 46: | Line 52: | ||
+ | According to this: | ||
+ | TODO: | ||
+ | * Find datasheet for stepper motor in machine | ||
