user:zimmer62:autodvdloaderrobot:start [2013/09/21 15:47] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2013/09/30 13:47] zimmer62 |
Line 11: | Line 11: | ||
{{:user:zimmer62:autodvdloaderrobot:img_6752.jpg?direct&800|}} | {{:user:zimmer62:autodvdloaderrobot:img_6752.jpg?direct&800|}} | ||
- | {{:user:zimmer62:autodvdloaderrobot:img_6762.jpg?direct&800|}} | + | {{:user:zimmer62:autodvdloaderrobot:img_6762.jpg?direct&800|}} |
I documented what I could figure out from each connecting wire: | I documented what I could figure out from each connecting wire: | ||
- | * Bad Disk Full (Orange, Yellow, Green, Blue) QRB1114 | + | * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] |
- | * Bin Full (Red, Orange, Yellow, Green) QRB1114 | + | * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] |
- | * Drive Door (Blue, Black, Purple, Yellow) QRB1114 | + | * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] |
- | * Home Sensor (Red, Orange, Yellow) Sharp? (Yellow = E) | + | * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E) |
- | * Disk Present (Red, Black, Blue) Sharp? (Blue = E) | + | * Disk Present (Red, Black, Blue) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Blue = E) |
- | * Safety Int (Black, Read, Green) Sharp? (Green = E) | + | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) |
- | * Stepper Motor FL42STH47-1206AC | + | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] |
* 1.8 degrees 1.2A | * 1.8 degrees 1.2A | ||
Line 28: | Line 30: | ||
I don't need the safety interrupt, so that leaves me with 5 sensors, 1 stepper and 1 solenoid that I need to interface with. | I don't need the safety interrupt, so that leaves me with 5 sensors, 1 stepper and 1 solenoid that I need to interface with. | ||
+ | {{:user:zimmer62:autodvdloaderrobot:img_6756.jpg?direct&800| }} | ||
+ | That still left me with trying to identify that Sharp optical sensor since there are 2 of them I will need. | ||
+ | I can see that the blue wire here is the Emitter, I'd really like to find the specs on this to make sure I drive it correctly. | ||
+ | My search let me [[http://memakingthings.blogspot.com/2012/12/optical-interrupters.html|here]], not identical, but very close. The 361 chip on my board is a current limiting resistor. | ||
+ | A little experimenting with the lid sensor that I'm not going to need should help me figure out how to interface with this. | ||
+ | Ohhh I found it [[http://www.digikey.com/product-detail/en/GP1A75E3J00F/425-2565-ND/857214|@ DigiKey 425-2565-ND]] | ||
+ | [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] I'm still not sure from this how to identify the other two leads. | ||
+ | According to this: | ||
+ | TODO: | ||
+ | * Find datasheet for stepper motor in machine | ||
