user:zimmer62:autodvdloaderrobot:start [2013/09/21 15:37] zimmer62 |
user:zimmer62:autodvdloaderrobot:start [2013/10/01 02:32] zimmer62 |
Line 7: | Line 7: | ||
Drivers for newer operating systems are not there, and the software this works with is really only designed to copy a bunch of the same disc over and over. A band interesting in burning their own discs might like this. | Drivers for newer operating systems are not there, and the software this works with is really only designed to copy a bunch of the same disc over and over. A band interesting in burning their own discs might like this. | ||
+ | The first step was to remove all of the housing and electronics, and identify what things I can use and what each part is. | ||
+ | {{:user:zimmer62:autodvdloaderrobot:img_6752.jpg?direct&800|}} | ||
+ | {{:user:zimmer62:autodvdloaderrobot:img_6762.jpg?direct&800|}} | ||
+ | I documented what I could figure out from each connecting wire: | ||
+ | * Bad Disk Full (Orange, Yellow, Green, Blue) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
+ | * Bin Full (Red, Orange, Yellow, Green) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
+ | * Drive Door (Blue, Black, Purple, Yellow) [[https://www.sparkfun.com/datasheets/Sensors/QRB1114.pdf|QRB1114]] | ||
+ | * Home Sensor (Red, Orange, Yellow) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Yellow = E) | ||
+ | * Disk Present (Red, Black, Blue) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Blue = E) | ||
+ | * Safety Int (Black, Read, Green) [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] (Green = E) | ||
+ | * JP13 Greyish White Wires go to the Disc Release Solenoid. | ||
+ | * Stepper Motor [[http://jnker.com/equipment/step_pdf/Seriya-GD42STH_1.8.pdf|FL42STH47-1206AC]] (1.8 degrees 1.2A) | ||
+ | * Rated Voltage = 4V | ||
+ | * Power Supply 12V @ 2.5A | ||
+ | This should be enough information to get going. | ||
+ | I don't need the safety interrupt, so that leaves me with 5 sensors, 1 stepper and 1 solenoid that I need to interface with. | ||
+ | {{:user:zimmer62:autodvdloaderrobot:img_6756.jpg?direct&800| }} | ||
+ | That still left me with trying to identify that Sharp optical sensor since there are 2 of them I will need. | ||
+ | I can see that the blue wire here is the Emitter, I'd really like to find the specs on this to make sure I drive it correctly. | ||
+ | My search let me [[http://memakingthings.blogspot.com/2012/12/optical-interrupters.html|here]], not identical, but very close. The 361 chip on my board is a current limiting resistor. | ||
+ | A little experimenting with the lid sensor that I'm not going to need should help me figure out how to interface with this. | ||
+ | Ohhh I found it [[http://www.digikey.com/product-detail/en/GP1A75E3J00F/425-2565-ND/857214|@ DigiKey 425-2565-ND]] | ||
+ | [[http://www.sharpsma.com/webfm_send/637|Sharp GP1A75E3J00F]] I'm still not sure from this how to identify the other two leads. | ||
+ | According to this: | ||
+ | TODO: | ||
+ | 9/30/2013 | ||
+ | * Red Wire to 5V | ||
+ | <code csharp> | ||
+ | </code> | ||
