user:tim:start [2014/11/13 17:14] tim |
user:tim:start [2017/04/05 00:38] (current) |
* LMN | * LMN | ||
Line 67: | Line 68: | ||
Line 99: | Line 101: | ||
Line 132: | Line 129: | ||
Line 141: | Line 137: | ||
Line 170: | Line 166: | ||
Line 181: | Line 175: | ||
* mUVe3D | * mUVe3D | ||
* honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]] | * honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]] | ||
* improve dryer efficiency: http://www.alkeng.com/AL/dryer | * improve dryer efficiency: http://www.alkeng.com/AL/dryer |
