user:tim:start [2014/11/06 17:55] tim |
user:tim:start [2014/12/16 02:57] tim |
* LMN | * LMN | ||
Line 67: | Line 68: | ||
Line 99: | Line 101: | ||
Line 116: | Line 113: | ||
*BEACON | *BEACON | ||
- | * establish expected annual budget based on past expenses | + | * establish expected annual budget for maintenance, upkeep, recurring costs based on past expenses |
Line 132: | Line 129: | ||
Line 141: | Line 137: | ||
Line 170: | Line 166: | ||
Line 181: | Line 175: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 203: | Line 201: | ||
Line 268: | Line 267: | ||
* continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | ||
* establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | ||
- | * mission: skills and access | + | * mission: education and access |
