user:tim:start [2014/11/06 16:43] tim |
user:tim:start [2014/12/16 02:57] tim |
* LMN | * LMN | ||
Line 67: | Line 68: | ||
Line 99: | Line 101: | ||
Line 116: | Line 113: | ||
*BEACON | *BEACON | ||
Line 131: | Line 129: | ||
Line 140: | Line 137: | ||
Line 169: | Line 166: | ||
Line 180: | Line 175: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 202: | Line 201: | ||
Line 262: | Line 262: | ||
* where do we find them | * where do we find them | ||
* how do we communicate our mission | * how do we communicate our mission | ||
* include community members on board committees - voting rights? adjust bylaws | * include community members on board committees - voting rights? adjust bylaws | ||
* continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | ||
- | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / board member files | + | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting |
- | * mission: skills and access | + | * mission: education and access |
