user:tim:start [2014/11/06 15:32] tim |
user:tim:start [2017/04/05 00:38] (current) |
* LMN | * LMN | ||
Line 67: | Line 68: | ||
Line 99: | Line 101: | ||
Line 116: | Line 113: | ||
*BEACON | *BEACON | ||
Line 131: | Line 129: | ||
Line 140: | Line 137: | ||
Line 169: | Line 166: | ||
Line 180: | Line 175: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 202: | Line 201: | ||
Line 257: | Line 257: | ||
====== board goals ====== | ====== board goals ====== | ||
- | * build asset maps for LMN - committe | + | * build asset maps for LMN - committee |
* identify asset goals, and a plan to fill them | * identify asset goals, and a plan to fill them | ||
- | * include community members on board committees | + | * who do we need (what skills, resources?) |
- | * annual nonprofitnetwork board training, org reflection / reevaluation | + | * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation |
+ | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | ||
+ | * mission: education and access | ||
